Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
Thread: How to safely clean thermostat housing mating surface
  1. #26
    WA
    '95 325is 5spd
    Quote Originally Posted by Eric93se View Post
    I think it will be alright.
    Hexdump, what temp thermostat are you planning on running? Personally I use an 80c stat, less pressure on the systems plastic parts. You can find cooler thermostats by selecting an '88 325i, personally I don't think going below 80c is a good idea though but I've been using the 80c for over 10yrs now with no I'll effects.
    Man, I don't even know. I ordered it based on the part number: https://www.fcpeuro.com/products/bmw...at-11537511083
    I think it's a 92?
    Should this really matter for a daily driver / occasional "spirited" driver?
    Regarding the thermostat housing, FCP euro states that the genuine one they sold me with no BMW logo and no green sealant/gasket is a genuine unit. So I guess BMW has changed their design again? And no longer putting the roundel stamp onto genuine parts. Odd...
  2. #27
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by hexdump View Post
    I think it's a 92?
    The S52 got an 88C Thermostat
    11537511580
    non-‘M’ 325 /328/323 and S50 3.0L got 92C Thermostat
    11537511083
    Lower temperature, generally, equates to more component wear, slightly lower MPG and higher emissions.
    I believe most automobile engine manufacturers set their optimal operating temperature between 190F (88C) to 225F (107C) degrees Fahrenheit
  3. #28
    WA
    '95 325is 5spd
    Quote Originally Posted by bluptgm3 View Post
    11537511580
    11537511083
    Lower temperature, generally, equates to more component wear, slightly low MPG and higher emissions.
    Sounds like a solid argument to keep the 92C. What would be the reason to change?
  4. #29
    WA
    '95 325is 5spd
    I just got off the phone with a BMW dealer who had a genuine housing in stock. They sent me some photos of it. Looks like it does NOT have a BMW logo stamped onto it and it does NOT have the green sealant applied to it either.
    The gasket that comes with it does appear to be slightly "puffy" so it could be the oversized gasket.
    I guess BMW has decided that the oversized gasket and no green sealant is the way to go.
    Odd.
  5. #30
    Oct 2003
    Seattle
    99 M3
    To my knowledge the OE T-Stat Housing never had a surface sealant applied to the mating surface.
    And yes, the orange ‘thingie’ gasket that comes with the OE housing seems oversized and ‘bulkier’ than earlier examples., hence the recommendation to use the OEM Elring gasket
  6. #31
    WA
    '95 325is 5spd
    OK, is the current consensus to use RTV or not? Assuming I am using my OE housing.
  7. #32
    Jun 2010
    NY
    1997 328i
    Total bull crap, you pulled that straight out of your ass.
  8. #33
    Oct 2003
    Seattle
    99 M3
    No RTV.
  9. #34
    WA
    '95 325is 5spd
    Why do you think that a lower temperature thermostat would equate to less wear on the system?
    I'm no expert here but, so far as I see it, a lower temp would open earlier and coolant would start flowing through the block before a higher temp thermostat. That would mean that it would take the engine longer to get to optimal operating temperature. Why is that a good thing and why would it mean less wear on plastic components?
  10. #35
    Jun 2010
    NY
    1997 328i
    Your thread can die now.
  11. #36
    WA
    '95 325is 5spd
    Sorry man, did not mean to offend. I was just wondering what your reasoning was.
  1. Thermostat housing mating surface damage/corrosion/pitting
    By Ray2k in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-15-2019, 06:33 AM
  2. Thermat housing mating surface cleanliness?
    By isabura in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-02-2017, 10:14 PM
  3. cleaning block/cylinder head mating surface
    By newz3ownr in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-28-2016, 04:03 PM
  4. Cleaning the Block Mating Surface
    By BoaMan5 in forum 1991 - 1999 (E36)
    Last Post: 01-15-2016, 02:07 PM
  5. cannot clean vanos mating surface M50 325is
    By drpatso in forum 1991 - 1999 (E36)
    Last Post: 09-19-2015, 06:43 AM
