Results 1 to 5 of 5
Thread: 2007 Z4 AC and fan problem
    Aug 2021
    OHIO
    2007 Z4
    I used the reader and there are no error codes. When you turn the blower switch on the fan just runs on slow on all speeds. When you push the AC button it does nothing. Could someone help me?
    Oct 2012
    Victoria BC Canada
    2004 Z4, 1700 Nomad MC
    Another other post ( seems to be yours) refers to transport mode being issue.
    Transport mode can be initiated by low voltage. Check your battery hot/cold (Google if unsure what that means) and check alternator output…
    Use the following or similar voltage reader for cold voltage….voltage idling and when engine is at higher rpm.
    Car USB Charger, 5V 2.1A Fast Charging 3in1 USB Car Charger Adapter, Dual Led Digital Display Built-in Voltmeter Thermometer Universal Car Cigarette Lighter for 12V-24V Cars, SUVs, Trucks (Blue+red) https://a.co/d/gx7p5Q7
    Google … Z4 transport mode…. for more insight and posts to help you understand cause and symptoms….
    Aug 2021
    OHIO
    2007 Z4
    Quote Originally Posted by Clearancediver View Post
    I purchased this on Amazon Amazon.com: Creator C410 OBD2 Scanner for BMW Mini EPB ABS SRS DPF Oil Reset CBS Reset Battery Registration Full Systems OBDII Fault Code Reader Diagnostic Scan Tool [New Version Update of Creator C110+ C310+] : Toys & Games
    It is suppose to reset battery if changed or low. Would that fix Transport mode?
    Aug 2021
    OHIO
    2007 Z4
    Oct 2012
    Victoria BC Canada
    That model… highly doubt it.
    https://www.google.ca/search?q=hand+...&client=safari
    Read carefully…
    Still cheaper to download ISTAD and purchase a switchable cable to connect laptop to car OBED2 port. Plus full capability plus TIS support.
    My thoughts…. Hand held for basic readable codes… software to actually delve into the problem/ error code.
    I’m driving right now with a Bluetooth dongle in the OBED2 port and use “Car Scanner” app to clear an engine code popping up occasionally. It’s for the evap system and this one is solved by tightening gas cap. Annoying… but I also used my software to diagnose the issue and causes …. Plus… reading this forum which noted the gas cap being a cause.
  1. AC cabin fan problem
    By DaHose in forum 2004-2010 (E60,E61)
    Last Post: 07-09-2018, 03:10 PM
  2. AC / Aux fan problem
    By redlion2006 in forum 1996 - 2003 (E39)
    Last Post: 06-28-2014, 12:47 PM
  3. AC condensor fan problem
    By Tec Nine in forum 1996 - 2003 (E39)
    Last Post: 04-28-2010, 07:54 PM
  4. AC and Aux Fan problem
    By ctsiavalias in forum 1991 - 1999 (E36)
    Last Post: 05-31-2007, 03:33 PM
  5. ac + blower fan problems
    By frankie2003 in forum 1983 - 1991 (E30)
    Last Post: 01-29-2004, 04:35 AM
