Car almost spontaneously developed an issue where the engine would bog over 2k rpm and had a super rough idle. Unplugging the MAF immediately fixes the issue at hand.
Bought a brand new replacement OEM part, and the issue still exists with the new part installed. But simply unplugging the MAF connector continues to be ok.
What else do I need to look for here? Already replaced the sparks/coils cause I initially thought it was an ignition issue.
Vacuum leaks in the intake tracts allowing unmetered air in. Perform a pressurized smoke test to see them all and replace all the parts leaking.
Your MAF was reporting correctly.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
