Results 1 to 4 of 4
Thread: Seat Bottom Cushion Replacement Process?
    Jun 2023
    Missouri, USA
    2005 BMW Z4 E85 Roadster
    Anyone have experience with replacing the seat bottom cushion? My current one has a massive tear in it--managed to get this replacement cushion from a salvage yard online. Cannot find any resources which show what the process for the removal or installation of the cushions for the non-M-series seats.
    Any help appreciated. Images below for reference.
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Man, I did this to my car, including replacing driver's seat bottom and back as well as repairing the foam in the bolsters that breaks down from people sliding on them getting into the car.
    I thought about making a DIY but never got around to it. That said, I just started dismantling and ended up figuring it all out. This is what I can recall although it is not that fresh in my mind.
    You'll obviously need to remove the seat from the car - two 16mm nuts in the front and 16mm bolts in the back. Remove the seatbelt from the seat, which I think is also a 16mm nut. There is a torx screw that holds the two halves of the seatbelt guide together. Remove this to allow the seatbelt to be detached. Whatever you do don't let the belt retract all the way.
    After that you'll need to remove the rear seatback cover (two screws at the bottom then it should unclip at the top) and loosen the seatback leather to pull it around to access the bolts holding the seatback to the bottom. A couple hog rings in there I believe. Here are the bolts to remove:
    After removing the back:
    (That pic was during reinstallation. Notice I thought I would be clever and buy the leather from a passenger side seat, but then ended up with the suede on the outside of the seat. Oh well, no big deal. anyways...)
    Then you can take off the plastic cover on the seat controls. Mine has manual seats. I don't recall exactly how it is attached but I remember having to be careful not to break it. I think there is one screw then a couple hooks you have to finagle out. These pictures suck I know. But you can see where was the screw and the little catch that you need detach.
    Flip the seat upside down, and in the front, on either side, should be two screws that hold the seat cushion to the frame.
    Remove the two screws:
    Then I believe you can lift on the front of the seat and detach the rear from these mounts. It should just slide off. The rear of the cushion has these hooks that slide over the mounts:
    Here it is without the foam and leather:
    Installation the reverse of dismantle-ation. Not a difficult job but took at little time and patience. Was a great chance to make repairs and improve the seats a billion percent. Fixing the outside bolster was key. No more metal bar poking through.
    Good luck!
    Edit: Of course just looked more closely at the picture you posted above. You'll have to pop the cushion off of the metal frame that snaps and screws into the seat bottom. Not difficult, it just has some plastic strips that ride in a channel around the perimeter of the seat if I remember correctly.
    Last edited by clarkitect; 08-07-2023 at 05:39 PM. Reason: More info. Tryna be helpful.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Jun 2023
    Missouri, USA
    My man, this is phenomenal. Thank you so much.
    I imagine there will be others in the future who come stumbling here looking for the same advice.
    Rutland, Vermont
    Quote Originally Posted by DamienH View Post
    Glad I could contribute, hope it helps. Take some pix and offer any additional input as you do the job.
  1. 745LI front driver seat bottom cushion replacement
    By Mazzella.Chris in forum 2002 - 2008 (E65, E66)
    Last Post: 02-13-2020, 04:08 PM
  2. WTB Sport Seat Bottom Cushion
    By Jacksone30 in forum E30 Parts Classifieds
    Last Post: 10-03-2012, 10:37 PM
  3. Front seat bottom cushion and cover Dove Grey E36
    By uncle in forum BMW Parts Wanted
    Last Post: 04-13-2009, 07:43 PM
  4. Seat bottom torn - replace?
    By dmurray14 in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 07-25-2005, 12:59 AM
  5. WTB: Black m3 rear seat bottom cushion
    By UCLAguy in forum BMW Parts Wanted
    Last Post: 01-30-2005, 10:25 AM
