Results 1 to 2 of 2
Thread: persistant coolant leak
    Jul 2023
    maumee, ohio
    2004 bmw z4
    2004 Z4 with leak where lower hose connects to radiator. Tried 3 new hoses and a new radiator, and still leaks in the same location.
    Oct 2012
    Victoria BC Canada
    2004 Z4, 1700 Nomad MC
    Are you sure it’s the radiator hose/radiator … or is it the temperature sensor on the lower hose that is leaking.
    If not try a little bit of silicone lubricant/grease on the o rings and try again. The silicon lubricant/grease won’t harm the cooling system if used sparingly…vs… slapping on “gobs” of lubricant.
  1. E92 N54 persistent coolant leak
    By moneyposse in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 03-29-2020, 09:52 PM
  2. Replies: 9
    Last Post: 10-25-2016, 11:02 AM
  3. Persistent Coolant Leak
    By 528i 0WN3R in forum 1996 - 2003 (E39)
    Last Post: 11-15-2011, 04:54 PM
  4. Internal coolant leak on my 91 318is
    By cohiba in forum 1983 - 1991 (E30)
    Last Post: 05-03-2002, 02:59 AM
  5. Coolant leak problem
    By fstbmwm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-19-2002, 11:04 AM
