Results 1 to 6 of 6
Thread: 97 Z3 1.9 coolant sprayed out
    Jan 2022
    Sacramento
    1997 BMW Z3
    Just finished replacing the entire cooling system and the car has been running fine for the past month, but I did some spirited driving and as soon as I pulled in the driveway I noticed steam coming from under the hood and a puddle of steaming coolant.
    What caused it? I had about 50/50 coolant mix with a bottle of water wetter and the coolant level was about half way up the resevoir(at the cold fill level) the temp needle never went past 12 o clock
    Apr 2020
    Ontario, Canada
    1999 Z3
    Did you look under the hood?
    Mar 2023
    Mt Lemmon, AZ
    1998 BMW Z3 M Roadster
    If things are too messy to identify a specific leak then you can clean it up and borrow a radiator tester from your FLAPS to pressure check the system and recreate the leak in less dramatic fashion.
    Clamps (depending on style) often need to be further tightened after a heat cycle.
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    I would dry everything I could reach, let the car cool completely. Then I would start it. As it warms up I would look for coolant leaking. It could be as simple as a loose hose clamp.
    Feb 2009
    Charlotte, NC/Denmark
    2K Z3 2.8
    Quote Originally Posted by Cardriver333 View Post
    What caused it?
    Without opening the hood and telling us what you see, this is the most specific answer I can give you: "Something broke"
    Zed's dead baby. Zed's dead.
    May 2017
    NW Indiana
    2000 BMW Z3 M Roadster
    I had a small plastic pet cock on the bottom of the radiator fail…luckily my wife was taking the car somewhere and noticed a large puddle of AF in the garage as she was backing out….
    Also, if you overfill the reservoir, I think the pressure will build too much (no room for expansion)…
    You will need to investigate.
    Greg
    Tally Ho
    http://wcwebs.net/johnson
    1988 O'Day 322 sailboat - (unlimited mpg)
    2000 BMW Z3 M Roadster (25 mpg - but who cares)
    2019 Subaru Outback
    (30+ MPG)
  1. Z3 E36/7 WTB: oem cat for 1.9 97 Z3
    By byrona8 in forum Z3,Z4,Z8 Classifieds
    Last Post: 05-12-2010, 04:43 PM
  2. Z3 E36/7 Fs: 97 z3 2.8 in Seattle
    By redbaron58p in forum Z3,Z4,Z8 Classifieds
    Last Post: 03-01-2010, 11:06 PM
  3. Z3 E36/7 ’97 Z3 Seats
    By dontlift in forum Z3,Z4,Z8 Classifieds
    Last Post: 07-21-2009, 10:39 AM
  4. Z3 E36/7 WTB : Antenna Base for 97 Z3 1.9
    By lestat15 in forum Z3,Z4,Z8 Classifieds
    Last Post: 05-11-2009, 08:56 PM
  5. Z3 E36/7 WTB: Stock Rear Springs for 97 Z3 2.8
    By MGus23 in forum Z3,Z4,Z8 Classifieds
    Last Post: 04-09-2009, 08:54 PM
