Results 1 to 7 of 7
Thread: New Z3 Owner - Exhaust Clamp Bracket replacement
    May 2023
    Blairstown, NJ, USA
    2000 BMW Z3 2.3
    Hi all – I bought a beautiful black 2000 Z3 2.3 a couple of weeks ago, and will be replacing the Exhaust Clamp Bracket in the near future, and thought I'd see if anyone has any advice for me on this project.
    After I bought the car, I took it to a local BMW dealer for an oil change. To my surprise, upon completion they provided me with an excellent video pointing out potential problems. One of those problems is that the current clamp/bracket is severely corroded. So, I ordered a replacement, and expect to get it next week.
    My first concern is finding the best way to lift and support the car so I can get under it. Given how low the front end is, driving it up on ramps seems out of the question (although I've seen a video of that done on a 3-series using 2x4's as a kind of pre-ramp). Any advice here would be GREATLY appreciated.
    After that, I'm guessing the toughest part will be getting the old part off – thinking maybe my multi-tool can help there.
    I've attached a picture showing the part I'm replacing (in RED).
    Thanks in advance!
    Marc
    Feb 2019
    PA
    2001 BMW Z3
    Quote Originally Posted by Artrider View Post
    Driving it up ramps is not a problem...I've done it plenty of times to inspect and do work under vehicle.
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Some ramps have less angle to them, for lower cars. Please make sure you are safe. Wheel chocks are always a good idea.
    Apr 2020
    Ontario, Canada
    1999 Z3
    Since this clamp is near the center of the car, if it were me, I'd lift all 4 corners. I'm a little claustrophobic so I don't like squeezing under really tight spots.
    My method is a bit tedious but it works and feels safe to me. With a low-profile floor jack under the front cross brace, I lift the front of the car high enough to get a 6" X 6" X 18" block under each side at the jack pads. (I ran the 6" X 6"s over a jointer, on opposite sides to make good flat surfaces for stacking) I then move to the back and lift the car under the solid area of the diff (don't touch the fins) and place a 6" X 6" under both sides at the jack points. I then repeat this process until I have a stack of three 6" X 6"s under all of the jack points. This gives me a total height of about 16" off the ground and is very sturdy.
    I found out that that brace only properly fits in one orientation although upside down is very close.
    May 2013
    USA
    2001 Z3 3.0/5 roadster
    I accomplished the replacement of this part with only the passenger side jacked up at the front jack/sill point. It's only a few easy to remove bolts.
    May 2023
    Blairstown, NJ, USA
    2000 BMW Z3 2.3
    Good to know - thanks!
    Quote Originally Posted by delvec View Post
    Thanks!
    May 2023
    Blairstown, NJ, USA
    2000 BMW Z3 2.3
    Thank you!
    Thank you Delvec, Zellamay, Hoyt and Dakar. All very helpful info, and I appreciate your taking the time to respond.
  1. New Z3 Owner
    By RabidJ in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-04-2005, 09:21 AM
  2. New Z3 owner!... is anyone out there?
    By Dark Helmet in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-30-2004, 02:46 PM
  3. New Z3 Owner.
    By Shinobu in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-25-2004, 07:33 PM
  4. Yet another new Z3 owner
    By coffeeroaster in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-15-2003, 08:52 AM
  5. One more question from new z3 owner
    By onelap in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-30-2003, 10:16 PM
