Pothole.
Thx
I'm currently in diagnostic for high speed vibrations ( > 80 mph) .
Front suspension links looks fine. Not originals. Wheels balanced ect all tires are new.
Got rid of that 23 yrs old tire that was in front left ( spare tyre) : no change.
Do you think considering this was the front left wheel , other components could have suffered any damage , causing this high speed vibration ?
car has only 120km ( E39 540i)
Did you do an alignment with the new tires?
I did alignement only with two new rear tyres ( rear ).
Alignement was done before anyone notice I was driving with the original spare tyre. The accident occured in 2022 ( damaged tire date) so front tires were 1999 (not used ) and 2022 ( not used).
At the rear , tires were used on the inside.
Should I redo alignement now that all tyres are new ?
I got the car inspected by BMW when I bought it. Right front thrust was done and was changed , nothing else ( oils leaks obviously)
I was inquiring about the alignment because that would reveal if any non-visible damage was present.
Next task is to isolate whether you think the vibration is coming from the front or rear of the car.
I will redo alignement and wheel balance tomorrow then try another wheels then start to change parts..
This is from a pot hole long the side of the road. My daughter had the exact damage on her E36. In her case, the rims took all of the impact.
