RM European Auto Parts
Results 1 to 6 of 6
Thread: E90 330d stall on first start
    May 2023
    Scotland
    330d, 325 tds, e36 vert
    Hello, I’m having a problem with my 2006 e90 330d.
    It’s on 205k miles, and after the turbo blew and running away on itself, the turbo was replaced and was smokey ever since. So the decision was made to fully rebuild the engine.
    It got new rings, valve seals, head gasket, bearings the lot.
    It always started first time until the rebuild.
    So now it’s rebuilt I can’t get to the bottom of an issue. If I leave it overnight, the first start takes a couple seconds, then dies instantly. Start it agin straight after that and it will run rough for about 10 seconds then run absolutely perfect. Full power, no running issues at all.
    My plan is to sell so in reality I don’t really want to spend a fortune on it and start throwing parts at it.
    Any thoughts, or ideas to test would be a great help. Thanks
    Jul 2004
    Houston, TX
    36 Cylinders
    I would start with reading codes with a BMW capable scanner, as I'm sure there may be some, and then log fuel rail pressure and the in tank pump fuel pressure, as a start.
    Timing has to be spot on, and compression tests should be performed as well.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    May 2023
    Scotland
    There’s no codes, at first there were glow plug codes, but fixed that. Now none.
    I’ll check the fuel pressure with a snap on scanner.
    And the timing was spot on as that’s been double checked issuing timing tools.
    Thanks for your reply
    Jul 2013
    Casablanca, Morocco
    2001 e46 323i
    If you still have the old glow plugs, you could swap them in just to see if the issue stops, or changes in intensity. That could hint at the fact that the new ones, while not triggering fault codes, are problematic. Especially if they're not OEM plugs.
    "If you have integrity, nothing else matters. If you don't have integrity, nothing else matters." Alan K. Simpson.
    5spd E46 "3XX": 328i engine, 330i Intake and exhaust, CAI, 323i diff.
    Jul 2004
    Houston, TX
    36 Cylinders
    In non-freezing temperatures the glow plugs on any modern direct injection diesel have little to nothing to do with starting or running. The car will start without them even in freezing temps, but just harder.
    -Abel
    May 2023
    Scotland
    The problem was there before fixing the glow plugs, and after fixing the issue was still the same.
    So the glow plugs seem to not be related to the issue.
  1. smell of gas when first starting
    By skratch in forum 1992 - 1999 M3 (E36)
    Last Post: 12-08-2004, 10:33 PM
  2. Hard shifting in the morning/first starting out
    By LPSimpsons87 in forum 1983 - 1991 (E30)
    Last Post: 10-18-2004, 01:58 PM
  3. SC Car runs like crap when first started
    By Greg in forum Forced Induction
    Last Post: 09-26-2002, 08:47 AM
  4. Question about first start-up with new AA chip...
    By madsedan in forum 1992 - 1999 M3 (E36)
    Last Post: 04-03-2002, 12:39 PM
