Results 1 to 4 of 4
Thread: E24 CSI ITB's with AFM
    May 2023
    NYC
    1986 635csi
    Lightbulb E24 CSI ITB's with AFM
    I've been looking into putting ITB's on my 635CSI but everyone says I need to have a standalone ecu inorder to do that. Is there any way I can install it without? Is it possible to fab up a plenum around the ITB's and then have an intake tube with the sensor inbetween or am I just being a little slow and stupid. If it helps I could mock up a quick sketch of what it would look like. Just wondering as I havent seen anyone on either forum mention this or think of it but I do know its a thing in the honda community.
    May 2023
    NYC
    1986 635csi
    like this
    https://imgur.com/kvceoBS
    Last edited by 635Cami; 05-20-2023 at 12:26 AM. Reason: cant figure out how to add link
    Jul 2004
    Houston, TX
    36 Cylinders
    Many of the BMW engines have a similar setup to your drawing. If you do it well without causing turbulence across the air mass meter or changing the diameter of the AFM, then it should work fine.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Dec 2005
    Melbourne, Australia
    E24, E34 x2, E36
    The M635csi does this exactly. The only issue using the airflow meter is you are drawing all the air through a 2"x2" flap, and you would need to extend the wiring loom approx. 3 feet. I've changed to full standalone and the intake noise is much better without the air meter, so is the power.
    BMW’s
    90 E34 M5 stand-alone ecu, COP, flex fuel
    84 E24 M635csi (as per e34 M5)
    94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
    97 Z3 2.8
    97 E36 M3 euro SC still u/c
  1. E24 FS: E24 635 CSi or M6 $500 Euro Front & Rear Bumper & Trunk Spoiler
    By slownrusty in forum Exterior Lighting & Body Parts
    Last Post: 01-06-2021, 06:33 PM
  2. Replies: 0
    Last Post: 10-21-2018, 02:22 PM
  3. E24 E24 1989 635 csi For Sale
    By lilhodg in forum 5 series & 6 series
    Last Post: 09-19-2013, 11:42 PM
  4. FS - E24 CSI/M6 Mtech Spoiler
    By bmwphatpat in forum 1976 - 1989 (E24)
    Last Post: 02-13-2013, 01:16 PM
  5. Aluminum cleanup on e24 csi
    By KC Ron Carter in forum 1976 - 1989 (E24)
    Last Post: 12-03-2003, 09:55 AM
