Results 1 to 8 of 8
Thread: Identifying the hose to replace for CDV delete
    May 2023
    Los Angeles, CA
    1995 BMW M3 Coupe
    How do I know what hose to replace for the CDV? Is this the correct one? https://flic.kr/p/2ozna2L . Bit of a newbie with wrenching my car but decided to do this myself instead of paying some guy over a hundred dollars to install such a small thing
    Feb 2002
    Honolulu, Hawaii
    1997 M3, 2dr/5spd*
    IIRC just remove the CDV and reconnect the line, there's plenty of slack to do so...bleed clutch after. It appears that there's no CDV in that car in your picture...try doing some research, I don't think '95s had a CDV.
    Estoril/Modena '97 M3...sold for the second time.
    You only live once, and I'm running out of time...
    May 2023
    Los Angeles, CA
    1995 BMW M3 Coupe
    Was I correct in circling the right hose? I got the whole hose and cdv delete set here Stainless Steel Clutch Line & CDV Delete for BMW E36 325i/M3, Z3 (bimmerworld.com) so I have to replace the whole hose.
    Feb 2002
    Honolulu, Hawaii
    1997 M3, 2dr/5spd*
    Quote Originally Posted by tomatocookie View Post
    Did you read my post? Apparently '95s don't have a CDV...there doesn't appear to be a CDV in the picture you sent. Send your part back to Bimmerworld for a refund.
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    As Gene said; You do not have a CDV and it does not require a new line if you do.
    Jun 2012
    San Antonio, TX
    1995 BMW M3 Coupe
    My ‘95 never had a CDV. So, confirming what others have said.
    If you are experiencing clutch release issues, it is a different problem, not related to any CDV inline.
    KC
    1995 M3 & 1998 M3 coupes
    Quote Originally Posted by RBNetEngr View Post
    My 95 M3 didn't have a CDV inline either. My 98 M3 of course did, before I swapped out everything clutch related.
    Nov 2023
    Fairfax, VA
    1997 M3 Sedan
    I have a CDV delete if anyone wants. From UUC and brand new in the box still
  1. clamping hydraulic hose for CDV delete
    By zjdees in forum 1996 - 2003 (E39)
    Last Post: 04-14-2017, 01:30 PM
  2. Radiator Hose Replace and Fan Delete
    By JustinHalverson in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-23-2015, 07:37 AM
  3. E36 #714 CDV-delete clutch hose failed within a year.
    By Mystikal in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-05-2015, 01:25 PM
  4. Clutch line replacement troubles (CDV hose thing whatever delete)
    By Plox in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-10-2015, 07:15 AM
  5. Z3 E36/7 CDV Delete Hose - 21521159714
    By kobayashi in forum Z3,Z4,Z8 Classifieds
    Last Post: 01-31-2011, 10:22 PM
