Results 1 to 2 of 2
Thread: The window trunk in E61 doesn't open
    Aug 2012
    Poland
    E46 328
    Opening the window by inpa also doesn't work.
    The controller(computer) works in another car.
    The wiring to the motor is good, when voltage is applied to the controller pin under the glove box, it opens.
    The controller does not respond when the ground is applied to the pin in the controller (Directly applying a signal of pressing a button to the controller).
    The trunk gives a signal of closing and opening (light), but maybe someone smart gave two separate signals to the bulb and the controller?
    I don't see any other options, what about you?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    There are many reports of hatch wiring problems, but if that is the answer, I don’t understand why you can trigger from the controller pin under the glovebox.
  1. Windows don't drop, trunk doesn't open
    By olajon in forum 8 Series (E31)
    Last Post: 12-22-2010, 06:49 PM
  2. Trunk doesn't open...looking for fuse
    By Junaid in forum 1999 - 2006 (E46)
    Last Post: 02-16-2009, 03:55 PM
  3. Anyone else have a trunk that doesn't open
    By Righteous in forum 1991 - 1999 (E36)
    Last Post: 12-11-2008, 06:34 PM
  4. trunk doesn't open on '04 530i, anyone?
    By motopokep in forum 2004-2010 (E60,E61)
    Last Post: 07-07-2008, 01:13 AM
  5. 528it trunk doesn't open
    By kashmir88 in forum 1996 - 2003 (E39)
    Last Post: 05-08-2008, 11:35 PM
