Results 1 to 7 of 7
Thread: New E39 owner CD bluetooth question
    Mar 2023
    Belgium
    323ci
    Hi all
    I just bought a 2003 Touring 525i Lifestyle edition. It has the MKIV computer sat nav TV with cassette. In the boot/trunk there is no CD player (not expected as it wasn't in the VIN listing). I was wondering what Bluetooth adaptor I need for this? Many say to replace the CD with a bluetooth adaptor but as I don't have it, what should I look for connector wise?
    Many Thanks
    David
    Germany.
    Feb 2020
    PNW
    2001 530i Touring
    If you are considering using a Bluebus as your Bluetooth solution (which I recommend highly), then you could reach out to Ted, the owner. He's very knowledgeable and responsive, in my experience.
    https://www.bluebus.dev/
    Mar 2023
    Belgium
    323ci
    Thanks so much! I will.
    https://www.bluebus.dev/[/QUOTE]
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    +1 on Bluebus - just did it. Very nice. If your car is prewired for CD changer, then it is plug and play. There are videos out there on hookup demos. You should be able to use that to see if you are pre wired.
    Mar 2023
    Belgium
    323ci
    Quote Originally Posted by CPHES View Post
    I don't think mine is prewired for the CD although it might be. Below the DVD drive it has the empty frame and at the bottom 2 small connectors. Might be that? No larger connector..
    Nov 2016
    NY
    2 small connectors. Go look at Bluebus.dev and the YouTube videos. The e46 Vert has two small connectors- works great
    Mar 2023
    Belgium
    323ci
    Thx!
  1. New E39 Owner with an OBC Question
    By jdholder in forum 1996 - 2003 (E39)
    Last Post: 09-25-2010, 01:47 PM
  2. New 04 owner with bluetooth question
    By ///Arman in forum 2001 - 2006 M3 (E46)
    Last Post: 09-20-2005, 08:25 AM
  3. New Bimmer Owner (few simple questions)
    By StriktlyBidness in forum 1991 - 1999 (E36)
    Last Post: 10-29-2003, 02:22 PM
  4. new e36 owner, plus a question..
    By kt1 in forum 1991 - 1999 (E36)
    Last Post: 10-23-2003, 01:08 PM
  5. Woohoo! New 740iL Owner (and some questions)!
    By Paradoxish in forum 1995 - 2001 (E38)
    Last Post: 04-12-2003, 12:58 AM
