Bavarian Soundwerks
Results 1 to 2 of 2
Thread: 2019 530i - Stock sound system: NEEDS UPGRADE
    Mar 2023
    Phoenix, AZ
    2019 BMW 530I
    I got a 2019 530i w/a stock audio system. In dire need of an audio upgrade. Need solid bass and the rest.
    Best options? Thoughts?
    Has anyone upgraded before?
    Thanks,
    George C.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    First, set a spending limit. That is, the total amount you want to spend. Then determine if you or an audio shop will do the work. Next, what level of sound quality are you trying to reach. Obviously, that’s impacted by the budget. That is, a budget of $5000 would likely provide a level of sound quality an audiophile would like.
    I recommend you split the budget into three “buckets”:
    - speakers - 50%
    - electronics - 40%
    - installation/miscellaneous - 10%
    Now, installing speakers in a modern BMW is pretty easy as all you have to do is remove the door card and swap speakers. Quality speakers will be built to be installed in your bimmer. Be advised that mid-range speakers for your car will have 3 mounting holes, and not the traditional 4 holes!
  1. Few things and e30 upgraded stock sound system question
    By vschinzel in forum 1983 - 1991 (E30)
    Last Post: 05-09-2005, 02:23 PM
  2. Are you e34 guys happy with your stock sound system?
    By JAlfredPrufrock in forum 1988 - 1996 (E34)
    Last Post: 11-23-2004, 08:37 PM
  3. Did the stock sound system on your E39 satisfy you?
    By lb5er in forum 1988 - 1996 (E34)
    Last Post: 04-19-2004, 12:39 PM
  4. Does the stock sound system really suck that bad?
    By cS in forum 1991 - 1999 (E36)
    Last Post: 12-13-2003, 12:59 AM
  5. Graft high-quality pull-out to stock sound system?
    By Mickey in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-04-2002, 09:25 AM
