hi
i am new here
my car is 728 e23 with L jetronic, "banana" intake manifold
my engine need to be replace.
the only engine i found here in israel is e32
m30b30 with motronic injection system
i will keep the L jetronic system and the intake manifold.
what other things i need to look for in this engine replace?
flywheel?
distributor?
engine mounts
thx for your help
hi
i am new here
flywheel?
distributor?
engine
thx for your help
Just my opinion, but if you can get the wire harness and ecu from the e32, you are much better going with the Motronic.
I can't remember of the top of my head, but does the e32 even have provisions to mount a mechanical advance distributor?
i need to replace the timing chain cover and put the old one that can get the old distributor
then put a special screw in the end of the camshaft.
