Results 1 to 6 of 6
Thread: Cost to damn much DME
    Mar 2023
    South Carolina
    2020 430I Gran Coupe
    Hi I recently just got my 2020 430I Gran Coupe back from the shop due to a blown DME I had to have a brand new one built by BMW and shipped to the States took 90 days due to logistics and Availability of materials so they claimed. I was running Boot Mod stage 2 when it all went sour, I have a catted DP and did a Muffler delete prior to install of Boot Mod. My question(s) Will uploading BM3 without a battery charger cause my DmE failure due too Voltage dropping below 14V while uploading my tunes? 2nd or could it stem from a faulty tune stemming from BM3? 3rd: did I just get lucky & have a bad Dme my coolant line burst and was repaired under warranty by Century BMW in Greenville sc, I want to reflash it back on but im now cautious and afraid of doing that bs again. I reside in the interior of SC I have access to NC & GA before and if i ever decide to put BM3 back on my Gran Coupe I want to dyno my car and was wondering if anyone know of any reputable dyno shop in any of the 3 above mentioned states who can tune this car properly my check engine light is on due to my car running rich and want this issue fixed. Thanks in advanced for the assistance to my questions
    Jul 2004
    Houston, TX
    36 Cylinders
    What exactly was bad with the original DME?
    Was the car running with the original DME?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I use a power supply supply when flashing or programming. They aren’t cheap, at $200-400. Mine is an MST-80A if I remember correctly. Googling flashing or programming one of these newer complex ECU in a newer car with high battery drain rate will yield explanations of the importance of the power supply.
    There is a reason tuners, including BM3, instruct you to use one. Probably, if you had, you would not have bricked your ECU. There may be some tuners who could have recovered it, but I am not sure. Going to a BMW dealer for help will, as you found out, result in a large bill.
    Some people have used battery chargers. They can work but are not the same as a power supply. Some have also used battery boosters, but that may be even riskier.
    Jul 2004
    Houston, TX
    36 Cylinders
    https://www.bimmerforums.com/forum/s...30i-Gran-Coupe
    Crossposted here.
    If it was just a flash failure, then I highly doubt the dme was bad. These DMEs are very very recoverable from just about anything. I flash hundreds and actually recover a bunch from failed BM3 flashes. BM3 can be buggy depending on setup. I haven't found once when it's not recoverable. Power supply is recommended, but it won't be the cause of failure here.
    -Abel
    Feb 2009
    Arizona
    1998 e36
    if you worry about parts costing too much then why are you messing with them?
    Jul 2004
    Houston, TX
    36 Cylinders
    Wait till he finds out that the new dealer DME is the 06/2020++ hardware and there's no real good way to unlock for tuning. In for bricking #2?
    The initial fail could have been easily solved, but instead they took it to the dealer.
    -Abel
  1. What does a DME cost?
    By kabel in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-21-2011, 03:13 PM
  2. DME or Coil Costs?
    By Zonyx in forum 8 Series (E31)
    Last Post: 10-21-2009, 11:21 AM
  3. How much will that cost to reprogram the Dme
    By Mathes330ci in forum 1999 - 2006 (E46)
    Last Post: 02-06-2008, 05:58 PM
  4. When it rains, it pours. Damn Master Cylinder. Cost Question
    By AuburnGrad323is in forum 1991 - 1999 (E36)
    Last Post: 01-08-2008, 11:35 PM
  5. WTB: 95 325i DME at any cost!
    By TX S3 in forum BMW Parts Wanted
    Last Post: 11-20-2003, 11:38 PM
