Results 1 to 5 of 5
Thread: Drivetrain malfunction!!! Plz help
    Mar 2023
    North Africa
    Bmw F10 535i 2011
    Hi folks hope my topic find you well…
    I have F10 535i 2011 126k miles on it..
    The car runs smooth and idle very normally with acceleration normally. But on highway ( 80mph) or on hard acceleration i got drivetrain malfunction frequently, switched off and restart the car runs smoothly until a hard acceleration or at high speed (80mph)i got this drivetrain malfunction and the car output being so weak (something like limp mode) and drive normally but so weak.
    Upon the diagnosis i found the codes :
    1-charging pressure control plausibility pressure too high. (Intermittent)
    2-charging pressure control switch off as consequence. (Intermittent)
    Note : i have engine check light (catalytic converter below efficiency) but i think its not related to the problem.
    Could anyone help me to fix this problem plz !!!!
    Thank you so much.
    Mar 2023
    North Africa
    Bmw F10 535i 2011
    Plz help
    In a hole... My Hole....
    E39540i E60535 F10535i
    Based on what you have provided, I am thinking it may be a Diverter Valve failure.
    The Harder I work, the better I live!
    Mar 2023
    North Africa
    Bmw F10 535i 2011
    Quote Originally Posted by SHWELL View Post
    I was thinking about boost selonoid but not diverter valve . What do think the priority is for !?
    Jan 2017
    CA
    M3
    when was spark plugs replaced? I had similar issue around 150k. spark plugs were worn to the point where under load it was not able to provide the spark needed.
  1. 2014 BMW 328i Dreaded Drivetrain Malfunction... Please help
    By IMFritz in forum 2012-2019 (F30, F32, F33, F34, F36)
    Last Post: 06-07-2020, 12:00 PM
  2. Drivetrain Malfunction Help
    By llTrip in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-07-2019, 02:28 PM
  3. 2011 F 10 HELP Drivetrain Malfunction after replacing oil cooler gasket
    By swansailor in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-03-2017, 03:51 PM
  4. Electrical malfunction!!plz help!!lemon law??
    By grandtheft87 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 04-13-2011, 12:21 AM
  5. <Hazard Light Malfunction> Plz Help.
    By 735il1998 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-27-2009, 09:21 PM
