So, Ive got sand sport seats that are aging. I've found a bargain on full black massage / heat front/rear seating + switch panel. Both cars are 2001.
Is it just a matter of wiring + coding?
I know there must be a thread but the only one I found so far was PFL to FL which, I don't have that challenge.
TIA!
2001 | DINAN 7 Sport | S62 Swapped 6-Speed
DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
Dual Pane Glass | Black & Sand Int.
2001 | 750iL | AlpineWeiss III
@scotthduke on Instagram
Found this http://www.bimmerboard.com/forums/posts/567475
But may not cover what I need.
If they are both 01 - yellow plugs - simple swap. Base sport in an e38 is sport contour with no heat, or are you asking for base e39? I put a no heated e38 sport contour into a 99 e39 sport touring, and it all works. ( the e39 has the same yellow plug ). Massage back then only came on comfort seats - not sport contour. If this is a sport contour with massage, someone did it at home.
