Results 1 to 9 of 9
Thread: WinKPF unable to find ZUSB
    Mar 2023
    Germany
    BMW E46
    Hey there,
    i am trying to update my E46 320D, but WinKPF does not find my ZUSB. I Have updated the E46 SP Files many times but nothing is working. I have so many in there but none of them matches my ECU.
    I checked the Sticker on the ECU itself its Number is:
    DDE 7 794 624
    Bosch 0 281 011 122
    How can i proceed now?
    Jul 2004
    Houston, TX
    36 Cylinders
    What are the last 7 of your VIN?
    You only provided the hardware part numbers, so there's nothing you can do with those.
    What is the current software number ZB, from INPA diagnosis?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Mar 2023
    Germany
    BMW E46
    I have checked the car with INPA and took screenshots. Hopefully these will answer the questions.
    https://picr.eu/images/2023/03/23/C7O7j.png
    https://picr.eu/images/2023/03/23/C7ZYO.png
    Jul 2004
    Houston, TX
    36 Cylinders
    The update for you would be 7801004 (EU4, manual gearbox) found in DDE 5.03 list
    In configuration, make sure you have
    "Fast baudrate" NOT checked
    "Programming Voltage" NOT checked
    "Force Program Programming" not checked (optional, but faster this way in some situations)
    "UIF Write after data / program / in Comfort mode" checked
    If you are using K+DCAN cable, make sure the latency is set to 1 or 2ms in Device Manager
    -Abel
    Mar 2023
    Germany
    BMW E46
    I have updated the Car and it Starts the engine.
    In winkfp ist also under dde5.03 7801006 and 7801008. Do they also fit and are These newer Versions of 7801004 or are they for other ecu Versions?
    How did you found Out what i need to use as zusb?
    Jul 2004
    Houston, TX
    36 Cylinders
    The other ZB numbers are not updates for your car, it's for cars with other options.
    I used your VIN to reference the correct flash for your car.
    -Abel
    May 2016
    Wilkes-Barre, PA
    2000 740iA, 2003 330xiA
    Hi, I am also having this issue on my MY2000 E38 740i. When I type in the ZUSB found in INPA (which is 7505039), but I get the ZUSB not found error. I searched through the files using VS Code & I can find this ZUSB in the EK726.HIS file but not the .DAT file. What do I do next? Thanks for any replies.
    Jul 2004
    Houston, TX
    36 Cylinders
    That ZB is old. Why do you want to flash the same ZB?
    7539284 - flash this one, it's the latest update.
    -Abel
    May 2016
    Wilkes-Barre, PA
    I ended up flashing DME to this ZB. I was following a European member but my car is US spec, so caution to others, verify your vehicle matches the vehicle of the guide that you are following.
  1. ISTA-D, unable to find Readiness Codes
    By bryosb in forum Diagnostic Software
    Last Post: 07-19-2013, 12:09 PM
  2. HELP: Unable to find Clear/White Indicators for 2001-2003 Coupe
    By Oz Striker in forum 1999 - 2006 (E46)
    Last Post: 08-26-2007, 11:08 PM
  3. Unable to find - How many lbs are these injectors?
    By trimegatron in forum 1992 - 1999 M3 (E36)
    Last Post: 08-20-2007, 08:18 PM
  4. unable to find remedy for window problem
    By jonspahr in forum 1988 - 1996 (E34)
    Last Post: 01-30-2006, 09:50 PM
