Results 1 to 3 of 3
Thread: Ignition coil reality check please
    Mar 2013
    Alpharetta
    1998 z3
    Wife’s Z4 3.0si ran really rough yesterday, a bit of a noise etc. Code checker shows cylinder5 misfire. Swapped the coils between cyl 5 and cyl 2 to test and the misfire code wandered to cyl 2. Great! Simple coil swap right? But, getting Cyl 4 misfire now after putting a new Bosch coil in cyl 5.
    Ran rough after swapping cyl 5 coil.
    I will pull at least the cyl 5 spark plug and look for clues later.
    Thoughts please?
    Sent from my iPad using Tapatalk
    Oct 2021
    Toronto
    2008 Z4MC
    It might be time to change all of them for fresh coils, at least you eliminate that from the equation.
    I never replace coils one by one. If one is bad, I replace them all together
    May as well do spark plugs too. They are both part of the ignition system after all.
  1. how to check ignition coils
    By bruceb241977 in forum 1999 - 2006 (E46)
    Last Post: 09-12-2010, 12:02 AM
  2. ignition coil check?
    By danny2010 in forum 1976 - 1989 (E24)
    Last Post: 09-11-2010, 10:31 AM
  3. 89 535i Reality Check Please
    By Snellcomp in forum 1988 - 1996 (E34)
    Last Post: 03-16-2010, 11:20 AM
  4. dead rear shocks? reality check please
    By kyle242gt in forum 1992 - 1999 M3 (E36)
    Last Post: 02-02-2009, 07:45 PM
  5. E36 Checking Ignition Coils
    By renegadevii in forum 1991 - 1999 (E36)
    Last Post: 03-17-2008, 11:20 AM
