Results 1 to 3 of 3
Thread: Check Control Owners Manual - OBC not showing on cluster
    Mar 2023
    Vista CA USA
    1995 BMW 530i
    1995 530i. When first started through about mid-day, OBC data could be displayed on cluster via BC control. Then, BC would stop working (while driving) and when I turned off the car, “Check Control - Owners Manual” would appear with the gong/chime. Turning on the car would get the same chime and message and BC would not work. Next day - wash, rinse, repeat. Now, it’s permanent - I get the chime/message when starting and when shutting down; BC does not work at all. OBC itself works fine. I have tried a new CCM to no avail. I guess the connection between the OBC and cluster has failed but I don’t know where to start looking. Thanks in advance for any help you can offer.
    Apr 2020
    Budapest, Hungary
    '92 E34 M50B25 sedan
    Apr 2015
    Redondo Beach CA
    1995 530i
    Funny enough, the OP is my uncle who owned the car before me. I have it now, and we figured out that if you press on the lower dash trim just below the cluster and to the right of the steering column, the BC messages will display. Once you release pressure they go away. So there's probably a loose connection or a joint that needs re-soldered in that area. It's on my list to fix. I'll post back when I get it figured out.
    1995 BMW 530i | 2001 Range Rover 4.6 HSE | 2004 Porsche Cayenne S | 2018 Alfa Romeo Stelvio Ti Sport
  1. Indicator not showing in cluster
    By pietern740il in forum 1996 - 2003 (E39)
    Last Post: 06-16-2021, 05:42 PM
  2. 2005 BMW X5 4.4 gears not showing on cluster after replacing transmission
    By PurplePiff in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 05-28-2017, 11:06 AM
  3. "Check Control - Owners Manual"
    By Avenolpey in forum 1988 - 1994 (E32)
    Last Post: 02-28-2010, 08:15 PM
  4. Reseting check control on the OBC
    By NiTrOuSoXiDe in forum Convertible Questions
    Last Post: 11-06-2007, 02:05 PM
  5. OBC "Check Control" Not Working.
    By fukes in forum 1991 - 1999 (E36)
    Last Post: 01-03-2006, 05:48 PM
