Results 1 to 3 of 3
Thread: Is this an e39 540i manual transmission? 226.0.0276.90
    Mar 2023
    Toronto Canada
    E38 E39
    Hi, I was sold this 6 speed manual transmission for my e39 540i manual swap. The serial numbers on it have been coming up as a mix between a 3 series and 5 series on other forums. They are not the same as my other e39 manual transmission.
    Also, it has an orange ATF sticker, instead of the yellow MTF one. They had also given me a shifter assembly with linkages that are too long for a confirmed e39 M transmission.
    I ask someone to please help me figure out what car this transmission is from, as the seller claims it's from a 97 bmw 540i Manual.
    Thank you!
    Serial numbers:
    Bellhousing - 226.0.0161.90
    Middle - 226.0.0274.90
    Gearbox - 226.0.0276.90
    Aug 2013
    Champaign, Illinois
    2003 540i/6 Msport Sedan
    Images?
    A great ending is all you'll see..
    __________________________________________________ _____________
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Welcome to the forum Bruce.
    This is from my 2000 540.
    Bellhousing - 226.0.0161.91
    Gearbox - 226.0.0276.92
    I do have the original shifter and shift rod in a box somewhere. I'm sure I can dig it up if it will help you.
    I used the Rouge shifter and weighted selector rod when I changed the clutch.
    Here is the tranny.
  1. 2001 E39 540i Manual Transmission
    By Roxie in forum Whole Parts Cars
    Last Post: 05-10-2021, 02:24 PM
  2. E39 540i manual transmission input shaft seal help
    By jdobro22 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-16-2019, 08:42 PM
  3. E39 540i manual transmission
    By turboSlow in forum Drivetrain & Transmission Parts
    Last Post: 04-19-2019, 03:06 PM
  4. E39 FS 12/97 built e39 540i Automatic transmission
    By Nicks1k in forum Drivetrain & Transmission Parts
    Last Post: 05-22-2010, 07:47 AM
  5. E39 E39 540i Steptronic Transmission Automatic Differential and Parts
    By e36 bimmer in forum Drivetrain & Transmission Parts
    Last Post: 03-26-2010, 10:55 PM
