Results 1 to 3 of 3
Thread: Trying to start engine on crashed car
    Mar 2023
    Gorinchem - Netherlands
    2002 BMW 316i
    Hello, new here on the forum. I bought a BMW E46 2002. Planning to take the engine out for an engineswap. I want the engine to run before I start removing it.
    The car has crashed into a tree, with what looked to me minor damage (airbags did'nt go). However, cant get it to start, it will crank, just wont start. Do I need to reset the ECU to clear any faults? Does it need a reset after a crash?
    So did some research and found a few issues.
    Mainly fuses blown and ground issues. CAN issue (high engine temp) fixed.
    What I did/checked
    Synced EWS3 with DME
    Fuel pump is powered
    DME is reachable through INPA
    Airbag fuses are out to be safe. (I hope its not the starting condition)
    BST (battery safety terminal) hasnt blown, however, yellow cap was pried off/damaged. For testing purposes ive bypassed the main power line. Is the BST a culprit or can I rule it out?
    Starter is working and keys recognized, however no spark.
    Fuel is at main line.
    Weird things I can see;
    - 40 outside air temperature in dashboard (air intake sensor on MAF is working, I can see that in INPA)
    My DME is not MS42/MS43 but BMS46D1? (only one that doesnt give error in loading INPA)
    Battery voltage shows as 0,0V in INPA. checked out main DME relay, seems legit. (fuel pump etc ok) Is there a cable coming back into DME for this? (all main power for DME is energized)
    I have access to BMW TIS
    Below the error report for the battery;
    E R R O R M E M O R Y R E P O R T ------------------------------------- Date: 03/14/23 22:09:29 ECU: BMS46DS1 JobStatus: OKAY Variant: BMS46DS1 ------------------------------------------------------------- RESULT: 1 errors in error memory ! ------------------------------------------------------------- 124 Batteriespannung Hauptrelais Error frequency : 1 Logistic counter: 40 Spannung an Klemme 15 12.51 V Kuehlmitteltemperatur 9.75 Grad C Batteriespannung 0.00 V aufgetreten vor (abs. KMZ) 120400.00 km Unterbrechung Fehler momentan vorhanden =========================
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    The -40 is due to the outside temp sensor missing / disconnected- it’s below the right side.
    Apr 2013
    Mill Valley, CA
    2003 330cic
    Look up the no start guide by 50skid on youtube
  1. 88 E32 Shift Cable Getting hot when I try to start engine.
    By oovmeister25 in forum 1988 - 1994 (E32)
    Last Post: 05-24-2009, 10:48 PM
  2. tried to start the car today
    By byron in forum Forced Induction
    Last Post: 09-15-2006, 05:33 AM
  3. bmw dealer is trying to blame engine shavings have damaged my car due to the oil
    By dambro24 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-08-2006, 08:00 PM
  4. Car won't start Clicking when tried to start
    By Ireland in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-24-2005, 08:15 AM
  5. Car Dies when trying to Start.
    By dave162 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-10-2004, 08:04 AM
