Results 1 to 9 of 9
Thread: Attempting F30 Engine swap
    Sep 2016
    West Chicago
    2013 BMW 328i Xdrive n20
    Hello all recently found out there's been coolant inside the engine and I've been getting every code in the book. I plan on replacing the engine with either the N20 or N26. I'm pretty handy with bimmers as this will be my first attempt at replacing an engine. I have some questions can I put any n20 or n26 engine in an awd f30? Any advice or tips and are there any other reliable bimmer engines I can consider swapping?
    Jul 2004
    Houston, TX
    36 Cylinders
    As long as it's the same engine as yours, 328i/528i going into yours, then it's a straight swap. If you get an engine from rwd, you may have to swap the oil pan since yours is an awd model. Do not get an engine from the 320i unless you don't care; they have slightly different internals.
    There is no other more reliable engine you can swap without a major change of electronics or very custom work.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Sep 2016
    West Chicago
    If I have an N20 I could swap for the newer N26 right?
    Jul 2004
    Houston, TX
    36 Cylinders
    The engine itself is identical to N26
    -Abel
    Sep 2016
    West Chicago
    Ok great! and would I have to do anything to the ECU? or is it as simple as a straight swap?
    Canada
    750 F01, 850i, LR3 HSE
    Coolant in the engine? are you sure?
    Or is it oil in the coolant?
    Regardless it might be a faulty oil filter housing gasket has it has a gallery to the oil and coolant.
    What other faults do you have that leads you to replace the motor? Timing faults?
    If so then maybe it may be cheaper if you fitting it yourself, but you should also replace the timing chain in the replacement motor.
    The only difference will be pneumatic wastegate vs electronic, this you can swap over. Also injector adaptation/compensation with the replacement motor.
    Quote Originally Posted by shakmonster View Post
    Sep 2016
    West Chicago
    I took it to a mechanic after having multiple parts changed on it. They said they found coolant in the engine and the best thing to do is replace it since it wont turn over anymore.
    Apr 2023
    California
    2013 BMW 328i
    Help with engine swap n26 to n20
    hello Abel. My mechanic put an n20 engine instead of an n26 engine in my 2013 328i and now the car runs leans, I have a lean code P0171. There are no vacuum leaks, no other codes. Any suggestions on programming that may be needed to get the car running correctly ?
    Jul 2004
    Houston, TX
    36 Cylinders
    First you need a tool that reads BMW manufacturer codes from all modules. P codes are not comprehensive.
    Second, N20 *from 328i* is identical in hardware from N26 from 328i. It's not a programming issue.
    -Abel
  1. 2013 f30 no start after engine swap
    By usernames13 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-18-2022, 10:43 AM
  2. BMW F30 engine swap (help)
    By 207 in forum Engine Conversions
    Last Post: 05-08-2021, 01:08 PM
  3. e36 into e30 engine swap or 4cly turbo questions.
    By Cosmos///95Lux in forum 1987 - 1991 M3 (E30)
    Last Post: 09-16-2010, 01:56 AM
  4. Engine swap Upgrade
    By Drifter-X in forum 1991 - 1999 (E36)
    Last Post: 07-26-2001, 12:28 PM
  5. M3 engine swap
    By Vok in forum 1991 - 1999 (E36)
    Last Post: 03-06-2001, 10:35 PM
