Results 1 to 12 of 12
Thread: In-tank Fuel Pump Sourcing?
    Jun 2019
    LaGrange, GA
    1983 BMW 320i
    Hey Folks,
    My in-tank pump is a spectra premium I got when i bought the car, but it's been getting louder and I'm trying to find a replacement before it goes. If anyone has a lead on an airtex, I'd be greatly appreciative, as the OEM BMW is a bit rich for me.
    Mercer Island, WA
    88 325iC,'11ML350,'84RX7
    RockAuto had them for sale a while ago when I was looking for one, but not sure if they still have them. It was an Airtex and was very reasonably priced. Hope that helps…
    Aug 2021
    ct
    1978 320i
    Are you trying to replace the entire assembly? If it's just the pump your worried about, a chevy vega pump fits in the stock assembly just fine. Not so sure about other aftermarket assemblies and their fitments though
    Oct 2022
    Raleigh NC
    1983 320i S
    I used this one. Easy install. Quiet.
    https://www.turnermotorsport.com/p-6...al-set-up-kit/
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    The in tank fuel pump keeps full the main fuel pump its psi is very low Airtex E8198H has the easy to replace fuel pump motor and filter, contact Airtex directly by phone and ask for it--Trico Group now owns airtex, Michigan., otherwise like what was said you can mod the current fuel pump with a new low pressure fuel pump like Airtex E2025-Fuel Pump or equivalent , I have a new fuel pump I bought for my airtex in tank assembly-like $15/ free shipping. Sometimes when the in tank fuel pump gets loud its the strainer that clogged, take it out and clean it and see if that helps.
    https://www.bimmerforums.com/forum/s...irtex%20e8196h
    Randy
    Jun 2019
    LaGrange, GA
    1983 BMW 320i
    Airtex is officially out of business, acquired by trico and folded into Carter. The BMW fuel pump has been declared obsolete and cut.
    If anyone has a hanger assembly frame for the tank, let me know. One of the studs for the fuel level unit broke off on mine a while back.
    Oct 2022
    Raleigh NC
    1983 320i S
    You can actually delete the in tank fuel pump. There's a couple of threads about it if you search. It was added because of vapor lock in high altitude and very hot environments.
    Many early models didn't have them.
    Nov 2007
    Cool
    Quote Originally Posted by jbowen944 View Post
    I have two, one is dead, the other works not sure how well.
    Randy
    Sep 2023
    Colorado
    1979 320I
    320iaman/ Randy,
    Is one of those available for sale? I would be interested.
    Let me know,
    Lloyd
    Nov 2007
    Cool
    Hi Lloyd:
    1977-1979 2.0L did not use in tank fuel pumps, they came about in 1980-83 1.8L models and a lambda system. I have two backup Airtex in tank fuel pumps with replaceable filters and replaceable fuel pumps and both work just fine.
    Randy
    Aug 2021
    ct
    1978 320i
    Wow well TIL. My 78 has an in tank fuel pump but when I look it up on realoem it shows a completely different assembly unit than what's in there. Are the assembly units swappable between different fuel tank styles?
    I know the PO had some stuff done with the fuel tank but I never dropped it and investigated it and he didn't go into detail about it when I got the car.. This is good to know...
    Nov 2007
    Cool
    The 1977-79 had the fuel float gauge canister only, if one is running one with the in tank fuel pump it would have to be wired in with a second plug, basically one power wire since the oem ones use the gas tanks connected to the uni-body as ground.
    Randy
  1. In-tank fuel pump?
    By nightsurfride in forum 1975 - 1983 (E21)
    Last Post: 07-04-2011, 08:35 PM
  2. FS: Late model E30 in-tank fuel pump. Brand new.
    By Ryan Stewart in forum BMW Parts For Sale
    Last Post: 02-14-2006, 10:58 PM
  3. Testing in tank fuel pump...
    By Monk183 in forum 1975 - 1983 (E21)
    Last Post: 08-08-2005, 08:42 PM
  4. Out of tank FUel PUMP
    By base146ball in forum Forced Induction
    Last Post: 04-22-2005, 03:54 PM
  5. How to remove in tank fuel pump on 318?
    By twilightcall in forum 1983 - 1991 (E30)
    Last Post: 08-14-2003, 04:12 PM
