Results 1 to 15 of 15
Thread: E36 M3 Strut Bar Tower Nut Dimension Measurement
    Oct 2021
    Canada
    2011 E92 M3
    My friend just bought the E36 M3 strut bar to install for E36. I found a similar nut online that might be OK for him.
    Does anyone has a spare nut that you can help with the OD and H dimension shown below diagram?
    Very appreciated !
    Jul 2011
    Bay Area
    E36 M3, W204 C63, etc et
    Oct 2021
    Canada
    2011 E92 M3
    should be this one, but they are very expensive to replace.... $11 each
    https://www.ecstuning.com/b-genuine-...h/51712268565/
    I would appreciate if someone can take measurement of their strut brace cap nut
    Jul 2011
    Bay Area
    Ah yeah my mistake. Theyre cheaper on FCP
    Aug 2003
    USA
    E36 M3, 11 X5d, 16 F31
    Going to assume you are asking about the E36 but the title to the thread says E46.
    Overall height is about 22.5 mm
    Overall diameter is about 17.9 mm
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    Oct 2021
    Canada
    2011 E92 M3
    Quote Originally Posted by Jim E. View Post
    Sorry for the typo, I already corrected.
    Thank you Jim E and Braymond141 for the dimension, what about the smaller cylinder diameter and height?
    Jan 2006
    Oakhurst, CA
    What are you doing this for?
    That design above is based on an original but modified for use for other strut bars. I’m doing a production run soon.
    Oct 2021
    Canada
    2011 E92 M3
    Quote Originally Posted by Braymond141 View Post
    my friend just want to get cheap alternative since getting full set of six is nearly $50, but I guess nothing works for him
    This type of nut is highly customized
    Aug 2003
    USA
    You should just buy a set from Brett.
    Jan 2006
    Oakhurst, CA
    Just buy them from BMW. It’s expensive but that’s because they cost a lot to produce.
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    Yep, just buy them. $66 in the grand scheme of things E36 isn't bad at all...lol That little octopus hose under the intake manifold? $108. A door seal? Good luck. Those little nuts are essential for doing what they do. Nothing else does the job, but they don't wear out, that's a plus.
    The Netherlands
    DE-spec E36 328i/M3 cab
    Only the black paint, or whatever voodoo coating they have on them can wear off. Even touching them can leave some black 'stains' on your fingers.
    IG:
    Jun 2012
    San Antonio, TX
    1995 BMW M3 Coupe
    The finish on mine looks like crap, with spots of surface rust on them. Is powder coating a good option for them?
    Jan 2006
    Oakhurst, CA
    Quote Originally Posted by RBNetEngr View Post
    No. Powdercoating scratches easy and will add too much bulk to the nut. They need to be black zinc, or black oxide coated.
  1. E36 Wanting to buy e36 m3 strut bar
    By BMWkidM3 in forum BMW Parts Wanted
    Last Post: 04-18-2012, 11:49 AM
  2. OEM LTW Motorsports E36 M3 strut bar.
    By Garrett M in forum Suspensions, Springs & Shocks
    Last Post: 08-29-2008, 10:27 AM
  3. FS: E46 M3 Strut Bar Stepped Nuts
    By fmcfad01 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-18-2007, 12:21 AM
  4. WTB: e36 m3 strut bar - motorsport stock
    By chadd95m3 in forum BMW Parts Wanted
    Last Post: 07-27-2006, 08:06 PM
  5. FS: E36 M3 Strut Bar, Colgan Bra
    By peakay in forum BMW Parts For Sale
    Last Post: 09-27-2004, 04:01 PM
