Results 1 to 4 of 4
Thread: E36 Vf Supercharger issue
    Mar 2018
    phillipsburg, nj
    1997 328is
    So, im running into an issue with a small bounce on idle and every time i put the car un neutral it jumps the idle for a bit, Code 227 for cylinder mixture bank 1 and I have checked all the lines, leaks, compression, O2s are pretty new but the car just does not feel right
    During cruising LTFT stays at -11 for both, when i start idling, Bank1 goes to postitive 10 and bank 2 stays at -11
    Aug 2011
    Los Angeles
    my brother's ti
    probably a vacuum/boost leak.
    SC's really suck when it comes to boost leaks, such a PITA.
    THE ONLY WAY to solve this is to buy or build a boost leak tester. you need to be able to apply compressed air to the entire intake system. I recommend starting at 10psi and then spray down every connection with soapy water. guaranteed you will have leaks galore.
    Jul 2010
    Whitby, ON, Canada
    335GT & Z3 M Roadster
    I had similar issues with Mt ZF install. I had to smoke test several times with around 5-6psi and found a few vacuum leaks. In my case I ended up replacing entire flexible intake pipe with couplers and rigid tubing and found my oil filler cap was leaking like crazy. Replaced it and seems to be running good now although winter here, so limited testing.
    You need to smoke test that setup. There are leaks somewhere..
    Sent from my SM-S908W using Tapatalk
    My Rides:
    2016 f34 335GT stage2+ MHD FBO, custom carbon throughout!
    2000 Z3M
    too many upgrades to mention
    Aug 2011
    Los Angeles
    my brother's ti
    you can smoke test a naturally aspirated motor, but a boosted engine needs the be boost leak tested. Most tuners recommend testing at least 5 psi above the intended boost level..
  1. E36 WTB e36 vf supercharger intake pipe maf to charger
    By runsideways2 in forum Forced & Chemical Induction Parts
    Last Post: 08-08-2014, 10:06 PM
  2. E36 FS: BNIB VF Supercharger kit for OBD-II E36 M3
    By HamsM5 in forum Forced & Chemical Induction Parts
    Last Post: 03-24-2013, 12:51 PM
  3. E36 VF Engineering E36 M3 Supercharger
    By 4fifth in forum Forced & Chemical Induction Parts
    Last Post: 09-20-2011, 10:38 AM
  4. E36 OBDII E36 M3 Supercharger Kit (VF with TT Tune)
    By TechnoM in forum Race Cars & Track Parts
    Last Post: 08-08-2010, 09:14 AM
  5. E36 M3 AA Supercharger Issues Resolved!
    By 96INFMSM3 in forum Forced Induction
    Last Post: 05-22-2004, 12:33 PM
