Results 1 to 6 of 6
Thread: 2002 330i head gasket failure . .
    Apr 2012
    ny
    1998 328i
    Automatic
    how common is this failure after 130,000 miles ?
    am looking at a used one and seller says head gasket was replaced
    how much does this typically cost ?
    if its not normal was the car abused by lack of oil changes or riding it hard ?
    thanks
    Aug 2021
    ct
    1978 320i
    I haven't heard of anyone doing a preventative head gasket repair, it's typically only when the car overheats, which unfortunately is not uncommon... Block and head are aluminum, so if the repair wasn't done properly head or block could be warped, threads in block could be pulled, could be very bad... If the car was immediately shut off after overheating and head gasket was slapped on, could be ok, but if you aren't sure of the history I would be careful.
    Nov 2018
    La Habra, CA
    2002 525i
    Quote Originally Posted by enf1945 View Post
    Automatic
    thanks
    Failure is not "normal" at 130K. But if these things overheat then it's very "normal." Nobody goes through the brain damage of a HG replacement as a preventative measure. That engine was abused or neglected. Parts got old, cooling system failed, engine overheated and was repaired. if it's really cheap, and you have the ability to pull the head off, time-sert the block, recondition the head (if needed), then buy it. If you don't, keep looking.
    Current stable:
    2002 525i (Daily Driver)
    1994 SN95 Mustang 'Vert (The Bumblebee)
    2001 325i Convertible (Beach cruiser project)
    Sep 2022
    NJ
    Z3 323 328
    Pulling head partsare like $200+ (bolts, gasket, others) MUST MUST use new head bolts. Old ones stretched out. Need proper torquing sequence.
    Dec 2022
    Mooresville, NC
    2003 325i
    Seen more than one occasion where people confuse the head gasket with valve cover gasket. Worth confirming that.
    Apr 2013
    Mill Valley, CA
    2003 330cic
    Quote Originally Posted by mcbru View Post
    This
  1. Is this a head gasket failure symptom?
    By e36'n in forum Forced Induction
    Last Post: 06-05-2006, 02:31 PM
  2. Question About my Head Gasket Failure
    By Pink Floyd in forum 1991 - 1999 (E36)
    Last Post: 01-09-2006, 02:01 PM
  3. Question About my Head Gasket Failure
    By Kilomph in forum 1991 - 1999 (E36)
    Last Post: 01-08-2006, 08:27 PM
  4. Causes of Head Gasket Failure in S50/52?
    By RotaryBzzz in forum 1992 - 1999 M3 (E36)
    Last Post: 05-05-2005, 04:41 PM
  5. Head gasket failure due to fuel starvation?
    By M3RACER in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-24-2005, 09:59 PM
