Results 1 to 11 of 11
Thread: Rear Wiper Half Working
    San Diego, CA
    98 M3, 03 540it M-Sport
    '03 wagon, when I push the wiper stalk, the rear wiper does the full half twist as expected, but it stays there until I pull the stalk to it's original position, at which point the wiper returns to its starting position. It will never perform a full right twist/left twist cycle without my manually moving the stalk in both directions. Is there a limit switch or a sensor in the motor that isn't reading properly? I wouldn't think it's a wiring issue since it technically works.
    '98 M3 5spd - '03 540it 6spd M-Sport
    Jul 2012
    mitten
    525it,02 525it,73 2002
    I have read the wiper gears get very dirty and contribute to the problem.
    Some have cleaned and grease/lube with some success.
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    The pin in my silver wagons rear wiper arm fell out a while ago. This is the pin that goes into the hole in the wiper motors output pad, you see it when you open the glass hatch. The pin fell out, and I put it somewhere, where? Lol, it’s a mystery to me right now. Anyway, I tried looking for the diagram on the rear wiper drive on realoem, and can’t seem to find it, I’m starting to get pissed. Maybe I’ll have to just fabricate the pin and JBWeld the sucker back on. I really don’t want to go that route, if anyone finds it on realoem, post a link!
    Tavernier, Florida
    '99 2.8&Mcoupe, '03 Mini
    Quote Originally Posted by BimmrMeUpSnotty View Post
    Next wagon I find in the U-Pull, I’ll try to get the spring-loaded pin drive for the wiper.
    -Donny
    Feb 2014
    Alexandria, VA
    Quote Originally Posted by KeysCoupe View Post
    -Donny
    Is that what it was? It was spring loaded? Never had the issue before, and realoem is sketchy on the rear wiper assembly.
    San Diego, CA
    Yep, sure enough, my pin is gone too. I'll keep an eye out for wagons at my LKQ and just pull the entire assembly.
    Feb 2014
    Alexandria, VA
    Yep, I’ll do the same out here, but E39’s are scarce in the local yards out here, wagons, have not seen any but the two that I have.
    San Diego, CA
    a few years ago, we had 3 in a row at our LKQ, one with the black sport interior in damn good shape that I pulled for $300. Everything but the carpet and main lower trunk panel. I have a small list of parts I'd pull if I found another.
    Apr 2012
    Beaverton, OR
    79 242, 99 528iT, 11 TSX
    You are looking for part 61627067893. I am having a similar issue; the pin is still there, but the spring is gone. Anyway, the part is still available new for around a hundred bones. Not enough of an issue for me to start tearing into yet, especially considering it's a hundred bones I could put toward more fun things.
    Feb 2014
    Alexandria, VA
    Dude! Thanks for that!!! I’m gunna order it.
    Apr 2012
    Beaverton, OR
  1. rear wiper doesnt work
    By paulpg in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 06-08-2015, 05:51 PM
  2. Rear wiper not working (possibly motor), Aux not working, screen wash gone limp!!
    By N6PM in forum 1 Series & 2 Series (E81, E82, E87, E88, F20, F22, F23, F40, G42)
    Last Post: 08-26-2014, 05:04 PM
  3. Rear Wiper Stopped Working
    By whiteghost1 in forum E39 Touring / Wagon
    Last Post: 06-16-2014, 03:08 PM
  4. e39 530dT - Trunk window + rear wiper, not working
    By dabbiso in forum 1996 - 2003 (E39)
    Last Post: 02-12-2009, 03:02 PM
  5. Rear Wiper not working...
    By mtj0742 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 01-20-2007, 07:04 PM
