Results 1 to 7 of 7
Thread: Hvac question
    Oct 2022
    Ohio
    1989 e32 750il,1995 525i
    Hvac question
    Why would the hvac air sampler fan inside the control unit continue to run with everything switched off on the control panel(fan switch, heat temp selection wheels) all off? Keeps running even when key is off. Only to stop it is to pullfuse 20 under hood. Sometimes it stays running and sometimes it doesn’t when I turn key off. Btw my car has the analog simpler hvac controller. Not the auto sword style.
    Oct 2022
    Ohio
    Ok so maybe I’m crazy! I read around a little bit and found out that other models the fan times out for whatever reason. So I went and sat in mine for awhile and sure enough the fan shut off two consecutive times after 20 minutes on the nose. For what reason would the cabin air sensor fan need to stay running for 20 minutes after the car is shut off?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    independent ventilation? Some models have this, copied from the E36 manual: BMW's Independent Ventilation (also known as Park Ventilation). Page 87 of the 96+ 318,323,328 Manual: Independent ventilation*
    This ventilates the vehicle's interior and lowers its temperature using the heater or the air conditioner fan. The system is operated by the onboard computer, refer to page 77. You can set the time for the system to
    start; it will remain active for 30 minutes. You can also turn it on and off directly. As the system uses a substantial amount of electric current, you should refrain from activating it twice in succession without allowing the battery to be recharged in normal operation between use. The independent ventilation is available for use when the outside temperature is above 60 5F (166), but not when driving. The air comes out through the vents for the upper body area. The vents must therefore be open for the system to operate.
    E34 also has it as optional extra http://www.bmwe34.net/E34main/Upgrade/Ventilation.htm
    Oct 2022
    Ohio
    I think you’re misunderstanding what is running. It’s not the main hvac fan under dash/firewall. It the tiny cabin air temperature sampler fan thats mounted to the hvac control module above the ashtray. Not the main blower fan
    Jan 2005
    Japan
    fuse 20 is for
    EWS II drive away protection
    instrument cluster, check control
    multi function clock
    park, tail, underhood lights
    park ventilation/with IHKR / F3
    IHKR/F3
    OBC IV
    Maybe your IHKR control module is defective? That 64118367951 has 2 plugs, pull one after the other and test when the fan stops, then check the ETM which pin that is https://www.programainc.com/item_det...x?idproduct=65
    study the ETM how the fan could be powered even when ignition is off and key is removed.
    Maybe another member had the same problem and can help?
    Oct 2022
    Ohio
    Thanks Shogun.
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
  1. odd hvac question
    By 97BostonGreenM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-08-2006, 05:21 PM
  2. Help with an HVAC Question
    By texture in forum 1991 - 1999 (E36)
    Last Post: 01-10-2006, 01:30 PM
  3. HVAC Question: Air only comes out of front vents
    By kay in forum 1991 - 1999 (E36)
    Last Post: 03-03-2004, 05:46 AM
  4. 1995 M3 HVAC question
    By Concentric190 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-02-2004, 01:04 PM
  5. HVAC Question.
    By Stan Gable in forum 1992 - 1999 M3 (E36)
    Last Post: 06-16-2003, 10:16 AM
