Page 1 of 4 1234 LastLast
Results 1 to 25 of 93
Thread: V12 shuts 1 bank down revs or load
    Christchurch,New Zealand
    93 fjord grey 850csi
    I have been gradually working through the myriad of problems with my CSI which do appear to be mainly ignition based surprise surprise
    The last and perhaps most persistent has become that the ecu shuts down a bank when either under load(hard acceleration) or if you are gentle about 4000rpm
    At the moment I only have a peake fault reader which indicates a cid sensor problem they are both brand new and bmw
    oem sensors
    I will swap them this afternoon apart from this the ignition system is oem bremi and brand new although I haven't measure fuel flow accurately it's enough to wind my 2bar gauge off its scale and forest seemto change anything when I swap sides that the pumps supply
    Any suggestions will be much appreciated
    brian
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Quote Originally Posted by merlin840 View Post
    oem sensors
    brian
    Test both your crankshaft sensor and the Doughnut sensors. The little tabs on the doughnut sensors face the distributors
    You can do a quick and dirty test on your fuel pumps. Apply 12 V directly to them and listen for a difference in sound
    What spark plugs do you have in it?
    You can swap fuel lines back by the firewall and see if problem follows it
    Unplug your fuel pressure regulators and see if you get fuel coming out, if so replace
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The further you push the pedal the harder the spark finds it to jump across the electrodes due to the increased insulative properties of the denser air - so I would guess you are losing the spark on cylinders 6 or 12 - or the current is too low to be detected by the doughnut. The current depends on the right resistance plugs and HT leads:
    My BMW Repair YouTube Channel
    Yes will do again doughnut sensors and cps are new ngk bkr6ek from memory the 2nd brand new set i have already swapped the fuel lines an no difference will check the pressure regulators good idea
    Another thought maybe the o2 sensors are swapped
    Yes I've checked the resistance of the ignition leads 1 is brand new bremi the other is reasonable condition magnetcor all seemed OK at 600ohmsi have a msd coil who've appears red to make no difference may try out again
    BTW no eml light with these fualts and ignition on/off resets it to go a dirty dozen ��
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    from workshop manual for the M70 and I assume it is same for S70: crankshaft position/rpm sensor: 540+/- 10% ohm, ignition wires angled/shielded connectors 1+/- 20% kohm, spark plug connectors 5+/- 20% kohm, cylinder identification sender coil resistance at 20 degree C (68F) <1 ohm, pulse sender/crankshaft position sensor coil resistance 540 +/- 10% ohm, Donut/ cylinder identification M70, S70: Resistance at 3-pin connector. Measure plug between pin 1 + 2, ≤1 ohm, insulation resistance between pin 2 + 3: ≥ 10 MOhm
    Jan 2005
    Japan
    read my post 39 and 40 in this thread, I have translated partof that from the German forum where the M70 no start came from the defective DME relays, sometimes they worked, sometimes not https://www.bimmerforums.com/forum/s...te-Fault-Guide
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    So the CID error #16 will present itself in few different circumstances.
    1) Bad CID sensors (ruled out)
    2) Wrong spark plugs (rules out)
    3) Bad wire (ruled out)
    4) Weak coil?
    5) fuel starvation on the bank? (plug in the fuel pressure regulator and see if the pressure drops off immediately after the engine shut down.)
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    You may want to inspect the rotor, I experienced this recently. The rotor was bad and grounding out instead of delivering voltage to the distributor cap. 5 hours on the side of the road, 6 hours in a tow truck, and good friends troubleshooting found that one! Nothing like quality parts leaving the factory!
    Regards,
    Brian
    Cave Creek, AZ
    Hello all
    I have been working on the CSI yesterday trying to eliminate any possible faults that may or may not contribute to the errors i have i have found that the fuel pressure regulators were reading low once i had bought a fuel pressure guage that would read over 3 bar (mine maxed out at 2 bar) and found it was running 2.5 bar i have replaced them with adjustable regulators and interestingly i could wind it up to 5 bar! but anyway i settled on 3.1 bar which while it does run slightly better the engine still shuts down 1-6 when it hits around 3000 rpm if you are gentle with acceleration but closer to 2000 rpm under load and both banks if you continue heavy load (read heavy acceleration) but if you are gentle it will run on both banks pretty much continuously and if you turn the key off and on again its good to go again
    and the peake reader i have shows fault 10 which translates to a dud cid sensor and if i get it to shut down both banks it shows a 10 fault for both banks but just at the end of the day it started to show just error on either bank when i used the code reader on it which brings me to suspect the EML maybe my culprit especially when even when my reader the LED display glows faintly when the ignition is switched of for a short period and then it fades BTW the reader still works faultlessly on my friends E34 540
    my eml is a 12711403274 and i am leaning towards that being my problem although i have read shoguns post #39 and #40 and i will give this a test in the next few days
    just to recap
    new bremi leads
    new bmw doughnuts X4 (twice bmw original and the bremi ones)
    bremi caps x2
    bosch rotors x2
    new fuel pressure regs x2(fuel pressure does not waver at all during flight even when it shuts down)
    is this EML rebuildable? or perhaps exchangeable with a M70 one if i swap the chip in it?
    thank you for your patience
    Brian
    stop press
    well maybe
    i was talking to a buddy of mine who is in the auto electric trade trade and i mentioned my faults in the CSI first thing he said was hows your alternator when i said 13.8 volts he said too low its quite likely your problem
    while i thought was a little low i didn't thin kmuch of it
    I will update tomorrow when i pick it up and fit it
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    If you are reading CID code it's likely that, what spark plugs do you have?
    Did you replace the ignition coil?
    Ngk bkr6ek twin electrode plugs
    I did replace the coils with standard coils that I had from another e32 750i that I had it came with msd blaster coils and it made no difference
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Another possibility is that your fuel is getting cut to that bank an you have no combustion.
    But would that give cid fault?
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Yes, no combustion on cyl 6 or 12= no pulse
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    But surely even without combustion the spark still happened thus you still have a pulse which the CID should still pick up
    Sorry am I missing something or is this not correct?
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    Yeah, you're missing something... too much resistance and there is no spark.
    '91 850i 6sp (mint) (sold)
    Dec 2011
    CSRA, SC
    850Ci, Excursion
    I didn't read the whole thread, but did you verify there is a spark? If you disconnect the #6 or 12 injector and remove the spark plug and touch the threaded body to the grounded body of the car while the engine is running you will see if there is a spark or not.
    Yes there is a spark
    And new bremi leads measure 5.3k ohm
    And there is definitely spark as it runs until it hits 3500 pm where where the eml appears to shut cyls 1-6
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The EML does not shut the spark off - it shuts the injectors off to stop bore-wash - the spark should continue. If the spark is going then it seems to be an HT problem
    I have fitted a rebuilt alternator today instead of 13.8volts it produces 14.4volts and I imagine a considerable amount more amp's I always thought it was a 140amp alternator but apparently it's a rather anaemic 120amp I may keep an eye out for an early m73 140amp the at runs better but still not well and it still shuts doyen one bank at 3000rpm although now the coffee reader I have now just shows an error when I try to read
    The error's which make me suspect that the eml maybe faulty although I am going torrefit the original bmw doughnut sensor as I want to rule out the bremi supplied one which appears to be different from the original bmw one's
    apologies in advance for the grammar/spelling as I'm doing this on a cellphone and it's late ��
    Brian
    Dec 2011
    CSRA, SC
    850Ci, Excursion
    You fired the parts cannon and missed. As Timm mentioned the EML is not responsible for the function you're dealing with.
  1. Driver side bank down 1998 750il v12
    By James Bronze in forum 1995 - 2001 (E38)
    Last Post: 06-12-2015, 02:53 PM
  2. 96 750iL shuts the left bank off under heavy load
    By wipeout in forum 1995 - 2001 (E38)
    Last Post: 08-02-2013, 03:33 AM
  3. How do I track down an electrical load?
    By old skool in forum 1991 - 1999 (E36)
    Last Post: 01-19-2007, 03:41 PM
  4. VERY slow down-rev??
    By pw455 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-14-2002, 03:25 PM
