Results 1 to 17 of 17
Thread: Vapor barrier
    Jan 2023
    NY
    2003 540i
    Exclamation Vapor barrier
    Was doing my rear door vapor barriers today and I noticed the doors are pretty weak where the water was. 402B5607-F730-4415-A9F4-3603F62901FC.jpg Is there any way to reinforce this or should I not worry about it and slap the door cards back on
    Middle of a corn field
    E39 hamster/ruberbandPWR
    Looks familiar ... lol ...
    I sprayed mold spray and bleach cleaner on it ...
    Jul 2019
    Denver, CO
    1997 BMW 540i
    Fiber glass fabric comes to mind as a method of reinforcing. Not sure if that would work, but maybe it would.
    Jan 2023
    NY
    2003 540i
    My other question is do I need to buy new butyl or can I just heat up the old and reseal
    Sep 2020
    PDX
    2003 M5
    If it was me, I'd replace the butyl. But if that's not possible for you at the time then yes, you can heat up and reseal with the old butyl. Just make sure you have a small roller and press really hard down on the barrier so it seals.
    Quote Originally Posted by Wraffel View Post
    The areas where the barrier pulled away , there was dirt stuck to the butyl , so I heated up those areas with a heat gun and scraped a layer off , then added new stuff on top .
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Autoparts stores or Amazon should sell new butyl.
    Aug 2013
    Champaign, Illinois
    2003 540i/6 Msport Sedan
    The same roller you use for Dynamat or other rattle/sound absorbers works great and is cheap if you get it from a Dynamat supplier. I think they make it cheap so you'll buy their expensive product..
    A great ending is all you'll see..
    __________________________________________________ _____________
    Jun 2013
    Boston, MA
    99 528i/5, 05 ZHP conv
    This was trhe cheapest Butyl I found...comes in handy when doing vapor barriers. I use a heat gun and both heat up old and add new where needed.
    This Butyl is thin, 1/4 inch so double it up where needed.
    https://a.co/d/cwtI8X4
    3M Strip Calk, #08578, Black Color, Soft Butyl Rubber, Paintable Immediately, 1 ft Strips, 60/Carton
    Apr 2019
    Vancouver, BC, Canada
    2000 BMW 540i
    That happened to my rear door panel as well. I just dilute some bleach and wipe it down. Wait after like 10-15 min and clean off with a wet cloth. After letting it dry (hair dryer), I layered some fibre glass cloth and mixed some epoxy to reinforce it. A small thin layer is enough after fully cured.
    They don't ... not any more .
    When I walked in recently and asked for butyl , the response was , " what is that ? " .... lol .
    I am like , wtf ?!? .... lol .
    I had to hunt for it locally and finally found it in a Home Depot , in the back of the store ...
    Jan 2023
    NY
    2003 540i
    Quote Originally Posted by Jason5driver View Post
    called 4 hardware/ auto parts stores yesterday and nobody had any.
    would this work?3253FD55-85AC-434B-B52E-FDDFE08B3E41.jpg3253FD55-85AC-434B-B52E-FDDFE08B3E41.jpg
    Nov 2011
    Milwaukee, WI
    '03 530i/5sp Sport
    Jul 2017
    Turkey
    '00 540i M-Tech
    you should use free flowing super glues with fast cure time. just pour it evenly on the weak areas which will absorb it and become hard. that's how I saved mine.
    I think so ... ?
    What does it look like inside the box ?
    Sep 2020
    PDX
    2003 M5
    Can still buy 3M Windo-Weld Ribbon sealer at Napa and Advance Auto Parts stores. Make sure you specify windo-weld, not butyl.
    Also if your door car is even the slightest warped from water damage. Be sure to add a thin layer of the stuff around the panel clip holes. Water can get through them.
    Apr 2008
    Toronto
    850i, Alpina B7, E61
    I had the same issue on my 540
    The part that holds the puddle light was very bad and would no longer hold the light in place.
    I scrubbed the area with a brush and cleaners let it dry completely.
    Cut up an old plastic gift card and glued it in around the whole for the puddle light to reinforce and give something for the puddle light to hold on to.
    After that was dry I put 2 coats of clear Varathain on affected area.
    The door pockets also came unglued I took the opportunity and removed the ash trays and used construction adhesive to glue it back in place
    Along with adding door pocket lights and door handle lights
  1. Part Number for Door vapor barrier?
    By rao in forum 1992 - 1999 M3 (E36)
    Last Post: 12-05-2011, 06:43 PM
  2. Repairing Vapor Barrier
    By nolimt1121 in forum 1996 - 2003 (E39)
    Last Post: 09-11-2007, 09:14 PM
  3. How to re-affix the 'vapor barrier' back onto the door?
    By fritzintn in forum 1992 - 1999 M3 (E36)
    Last Post: 09-11-2007, 05:56 PM
  4. Factory Door Vapor Barrier
    By Chroman in forum 1991 - 1999 (E36)
    Last Post: 09-19-2005, 12:22 PM
  5. How to attach vapor barrier to door?
    By ziggysux in forum 1991 - 1999 (E36)
    Last Post: 06-14-2005, 05:19 PM
