Results 1 to 3 of 3
Thread: Smell When A/C Runs
    Rosevile, CA, USA
    2001 525i
    Smell When A/C Runs
    Our 2013 328i has a bad smell (like a wet dog) when the A/C comes on. This has occurred in the past and I've changed the cabin filter on a couple occasions.
    Outside of just changing the cabin filter again, are there any other areas where I check to see what the source of the smell may be?
    Jul 2004
    Houston, TX
    36 Cylinders
    This was quite common on F30 on cars that sit without running the AC.
    You can run a cleaning foam like this https://www.amazon.com/Lubegard-9603.../dp/B0007PHD0S
    It should be injected through the drain pipe underneath, found next to the transmission, it's a dark gray valved tube.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Rosevile, CA, USA
    2001 525i
    Thank you. I've ordered a can and I'll be trying this out this weekend.
  1. S52 - most common cause of burning oil smell after a hard run
    By GEN3RIC in forum 1992 - 1999 M3 (E36)
    Last Post: 07-27-2008, 12:29 AM
  2. Replies: 15
    Last Post: 02-19-2008, 09:32 PM
  3. Burnt clutch smell after high spped run??
    By Casebrius in forum 1992 - 1999 M3 (E36)
    Last Post: 01-18-2005, 03:35 PM
  4. My car wont run and smells like gas ???
    By Austin in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-01-2002, 11:19 AM
  5. rough running, smells like rotten eggs
    By tciancia in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-21-2002, 11:29 PM
