Delete
E36/8 2000 M Coupe Cosmos Black/Black
Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein, AKG Subframe/Diff, UUC TME Red/Caps, Swapped Front Hats, Ice>Link.
Those symptoms are perfect for either a viscous fan failure or a lack of airflow through the radiator due to a build-up of debris between the radiators:
My BMW Repair YouTube Channel
Delete
I would spend the small amount of extra time and pull the radiator and look between it and the condenser.
Fan is a left hand thread, put some antiseize on it when it goes back together and then you barely need to tighten it.
Buy a BMW Fan tool, worth the $20
Delete
This has been a great upgrade for the mechanical fan:
https://www.bimmerforums.com/forum/s...1#post30182131
Hope this helps.
Regards,
Brian
Cave Creek, AZ
Delete
Several thoughts/questions, in case any of these help...
Whenever an engine gets hotter at idle than when running, it's normal to question whether the fans are doing their jobs. Even new parts can fail, or just not work right out of the box. When the engine is getting hotter and idling, open the hood to see if a lot of hot air is being pulled past the radiator.
Are you saying you changed the sensors already, or that you're thinking of changing them? Of course, bad sensors, or the wrong sensors could give you odd readings. But that wouldn't explain why you see normal temps when cruising down the highway and hotter temps when sitting.
I don't know that car well. Is there any chance that the sensor wires got swapped, and that your gauge is reading the output from the radiator, instead of the engine temp?
When the engine starts to get hotter, what happens when you rev it a bit while sitting still? If the temp comes back down when reving it, then I'd wonder about your water pump, or whether something else is restricting flow at low rpm.
If you're ever worried about it overheating, when you still need to drive it, you could try turning the cabin heat on and blower on high. You could also try that just to see what happens. If it brings the temp down back down that would point to problem somewhere else, like the thermostat, pump, or radiator.
Does that car have a hidden menu to let you see what the temp says through the dash display (like the e39 does, for example)?
I've heard the cheap infrared guns work pretty well. You might try one of those, aimed at various places, to see what it says. For example, you might be able to see how hot the coolant is right as it leaves the engine. That might tell you a lot. You could also check the input and output for the radiator, and check various places on the radiator to see if it's getting hot where it should (meaning it has good flow).
Good luck!
Needs a new Radiator
Delete
Delete
Do not get anything other than the Nissens radiator. They are the best for these cars.
The Behr rads are complete crap.
Buy the Nissens.
'91 850i 6sp (mint) (sold)
Delete
Hey I also live in Texas.
I’m thinking your issue is related to your aux fan. I had my aux fan fuse blew last summer and the car did what you’re describing. Overheating only when stopped.
My e31 and my buddies e38 do the same thing where the aux fan regularly runs on speed two at stop lights. The temp gauge never moves because it’s dampened but you can hear the fan speed up when siting.
I’m guessing your temp sensor on the radiator might need replacing or the aux fan itself. Check outside the car with the ac on and look through the grill or take the cover off in the engine bay to see if the fan is spinning at low speed. Also check when your car is starting to heat make sure it’s the aux fan you’re hearing and not the engine fan clutch engaging.
Delete
Delete
If it overheats when you push it hard you either still have air in the system or your head gasket is toast...
Delete
The engine was designed to be self-bleeding - the problem is that they then stuck on a heater system that certainly isn't! If the heater system is not bled, as soon as your revs go up the air is expelled from the heater matrix straight into the water pump ready to be transported deep in the bowels of the engine.
Delete
Also, another thing to check is your fan clutch... I once had an overheating issue and I had replaced the fan clutch with new OEM Behr unit.
I was pretty much at a loss and replaced most other cooling components without any luck. Then I went back to the fan clutch, and tested it. Guess what, it was bad right out of the box! Replaced that and solved my problem!
