Results 1 to 6 of 6
Thread: F30 fuel tank vent line - where is this and how to change it??
    Feb 2016
    Toronto
    '13 BMW 320i xDrive
    So this error is popping up on a scanner and I’ve noticed that the car seems like it is burning more fuel ever since the check engine light came on. Scanner shows it’s some vent line. Is this the correct part below? Already checked the gas cap doesn’t seem to be an issue it makes the clicking sound as I turn it so it seems OK
    What where is this vent line and how can I change it? Is it easy to change or need to take it to a mechanic garage ?
    2013 BMW 320i xDrive (F30)
    ~145,000kms
    Jul 2004
    Houston, TX
    36 Cylinders
    The code is not for the pipe, it's for the electric wire.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Feb 2016
    Toronto
    '13 BMW 320i xDrive
    Electric wire? Where and what is it? Can you elaborate please?
    ~145,000kms
    Jul 2004
    Houston, TX
    36 Cylinders
    The vent *valve* is under the hood by the engine area, connected to some of the piping for the tank ventilation system. I'm really unsure why you're pulling up the parts diagram for the fuel tank. Oddly, the part picture you have is not what you looked up in realOEM. Although, that does look like the valve on the end.
    The valve is reporting a disconnection. This means either it's disconnected from its control wires, or the valve itself burned out.
    -Abel
    Feb 2016
    Toronto
    '13 BMW 320i xDrive
    Hi!
    I unplugged this and replugged it in and made sure it made a clicking sound but check engine light is still on. Where does the other end of this cable go to? I think it might be disconnected at the other end…
    ~145,000kms
    Feb 2016
    Toronto
    '13 BMW 320i xDrive
    Anyone got any idea where other end of this cable that connects into fuel tank vent valve is located ?
    ~145,000kms
  1. F30 F30 Fuel Tank Leakage - Warranty Extension
    By RBNetEngr in forum 2012-2019 (F30, F32, F33, F34, F36)
    Last Post: 12-22-2022, 04:35 PM
  2. E30 fuel tank vent lines - where do they go?
    By LukeP in forum 1983 - 1991 (E30)
    Last Post: 12-31-2012, 12:46 PM
  3. Fuel tank vent line check valve?
    By motohunter4 in forum 1978 - 1987 (E23)
    Last Post: 01-14-2011, 08:15 PM
  4. Fuel tank vent lines
    By sirius600 in forum 1991 - 1999 (E36)
    Last Post: 06-03-2008, 04:29 AM
  5. Fuel Tank Vent Lines
    By jrcook320 in forum 1975 - 1983 (E21)
    Last Post: 05-17-2007, 10:01 PM
