Results 1 to 11 of 11
Thread: in search of part number for expansion tank hose o rings
    Dec 2008
    fairport, ny
    2003 530 sport/1976 2002
    Dear Forum, My car is a 2003 BMW 530i. My coolant expansion tank has 2 hoses that clip onto it on the bottom. I assume they have rubber o rings in the coupler. Do any of you know where I could purchase them and if so what part number they would be? I just replaced the expansion tank and noticed that they seemed to leak a bit around the coupler when I connected the hoses. Once connected the leak seemed to stop but I suspect they are failing. Thanks.
    Nov 2011
    Milwaukee, WI
    '03 530i/5sp Sport
    RealOEM breakout is here: 530i Cooling System Water Hoses. O-rings may only be part of hose assemblies since breakout only shows engine fitting o-rings. You might not actually have a problem if they sealed once pressurized.
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    The best place to purchase these O-rings is your local auto parts store or nearest HF. For about $10, you can buy a box of 100 O-rings of different sizes. Then use Realoem to find the size of the specific part o-ring you are interested in.
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by Chedley View Post
    I bought the HF assortments, inch and metric, years ago without paying much attention to the sizes they contained. SELDOM is there a useful size for automotive or anything else I work on in them. They are also poor quality, surprise, right.
    My recollection is BMW doesn't offer the O-rings separately. Perhaps the same size is used elsewhere and they would actually have them but they aren't cataloged regarding those hoses. They expect you to buy the assembly. Same with the sensor that plugs into the hose.
    My suggestion is to measure for the size you need and buy good quality O-rings as needed.
    The HF assortments I bought were a waste of money.
    https://www.theoringstore.com/store/...e%20other%20ou
    Sep 2010
    Ooltewah, TN
    2010 BMW M6*2019 X3 M40i
    The issue could also be the expansion tank itself.
    There are quite few brands out there and some of them are bad enough that either opening or the o rings themselves are too big or simply bad quality.
    2010 BMW M6 SMG Coupe * Black Saphire Metallic * Full Leather Merino Black
    2019 BMW X3 M40i * Alpine White * Mocha Leather
    Former:
    1997 BMW 532M (528i with 3.2 S52 engine from E36 M3 / 5 speed manual)
    1998 BMW 540i 6 Speed
    2003 BMW M5
    Tavernier, Florida
    '99 2.8&Mcoupe, '03 Mini
    I always give O rings like these a light smear of silicone grease before re-assembly. I have disconnected/reused the O ring in those quick-couplings many time with no leaking or issues.
    -Donny
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    The expansion tanks don’t contain the o-rings, the hoses that plug into them do.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Snotty ... welcome back!
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Feb 2014
    Alexandria, VA
    Hey Stephen! Yep, they once again made the mistake of letting me back….
    Car-nation, WAH
    2002, e21, e30, e36, e46
    As far as I've found, there are no part numbers for the o-rings in the hoses.
    The 6 cylinder cars use a 38mm x4mm (id x cross section) in the radiator hoses.
    Nissen gives you spare o-rings when you buy a radiator from them... and I think
    they're onto something, as I've had even 6- month old hoses leak after
    disturbing them.
    t
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by Toby B View Post
    disturbing them.
    t
    Noted. This is the kind of information that ought to be assembled into a data base. Not that I'm raising my hand.
  1. What part number for Coolant Tank-to-Radiator?
    By Aleman in forum 1983 - 1991 (E30)
    Last Post: 05-08-2012, 12:12 PM
  2. whats this part # for the expansion tank?
    By persian451 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-23-2011, 10:32 PM
  3. Insurance claim: Need a little help searching by part number
    By 2000RedZ3 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-04-2007, 11:30 AM
  4. Expansion tank hose part number
    By drshoebocks in forum 1983 - 1991 (E30)
    Last Post: 10-10-2005, 11:02 PM
  5. E34 HU issue, I searched, need part numbers.
    By mETRo E34 525i in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-06-2005, 02:38 PM
