I’m putting a built motor in now so I don’t need this engine anymore runs and drives strong I went 10’s in the 1/4 mile with this set up you can see it running before I pull the motor out I made 600rwhp this is a drop in turbo set up for e30 e36 e39 it’s a 3.2 L S52 did oil changes every 2,000 miles if you want to swap out your old run down m50 m52 or even up grade from an m50 this is a good set up
If you take all the parts $5500 or I have the prices down below
-S52 motor from oil pan to valve cover with 42k on it $3500
-Head gasket and arp head bolts to drop the compression
-Spa turbo manifold $250
-precision 6765 turbo $750
-oil feed lines $40
-oil return lines $50
-3” down pipe $200
-3” full exhaust $500
-2.5” turbo to intercooler piping $50
-22rpd tune mass air and Ecu 60lb injectors $1000
I’m interested in the s52 an possibly the whole set up. I think I want a smaller turbo.
