Hi guys! My e36 has the following problem: when you start it, the car seems to cough, won't go, you need to wait until engine gets hot a little, and it will go but it feels very underpowered in low rpm, and in higher rpm seems like a huge different car... its not supposed to fast at all but its quite lazy anyways... any ideas why?
EVAP issue? purge control valve? possibly
A wild guess, you have a serious vacuum leak.
Your question was moved to the model specific discussion area.
88M3 AW 43k miles Project FS
Measure your crank sensor, should be close to 510 ohms.
Use injector cleaner over the next 3 tanks of gas.
