Results 1 to 4 of 4
Thread: 2003 Z4 2.5 Cooling fan high speed (Jet engine loud)
    Jan 2023
    Louisville Ky
    2003 BMW Z4 2.5
    Hello!
    I just replaced a leaking radiator and two leaking hoses. I also replaced the cooling temp sensor in the lower hose and the relay on the fan shroud. I have a mechanical water pump which I replaced last year along with the thermostat. I have drained the block and replaced the coolant and bled the system.
    When the engine warms to temp the fan comes on jet engine loud highspeed bypassing the lower speed. Ima good part changer but, not much on diagnostics. Little help please!
    I would install INPA if you can on an old laptop... software is free, the cable is ~$20 and then you can do a live readout of what all the sensors are reading
    Usually when the fan runs full speed, it is due to a faulty lower radiator hose temp sensor (radiator outlet). Without this signal, the car doesn't really know the temp of the coolant coming out of the radiator so runs at full speed to be safe.
    You said you replaced the lower hose sensor. Why was this replaced - was it faulty before hand? Preventative? Do you have the old sensor laying around anywhere? And what brand replacement sensor did you use?
    These fans also don't have a low and high speed per se. They are PWM controlled and the speed is variable.
    PRICE CUT on ALL FABRICS
    Jan 2023
    Louisville Ky
    2003 BMW Z4 2.5
    The lower hose was leaking at the O-ring and the sensor was showing some moisture also, sloppy fit. I ordered the part online from eEuroparts.com $21.59 with 2 yr warranty. I do have the old sensor and they look to be exact.
    Jan 2023
    Louisville Ky
    2003 BMW Z4 2.5
    Quote Originally Posted by BimmerBreaker View Post
    The lower hose was leaking at the O-ring and the sensor was showing some moisture also, sloppy fit. I ordered the part online from eEuroparts.com $21.59 with 2 yr warranty. I do have the old sensor and they look to be exact. Upon closer look the part was OEM. I feel as though I have the system completely bled because after running with the front elevated and driving, I have no room to add and the bleeder overflows with the screw out. I ran it today and the fan came on normal so, I let it run a few more minutes then took a spin. Back to high fan.
  1. 2004 E60 Cooling fan issue ( speed )
    By shugarbmw in forum 2004-2010 (E60,E61)
    Last Post: 12-09-2016, 05:15 AM
  2. Z4 E85,E86 FS: 2003 Z4 3.0i Silver/Black 6-speed SoCal
    By beemwe in forum 3 series & Z Series
    Last Post: 09-26-2012, 12:29 AM
  3. Cooling fan shuts off and engine overheats
    By triplem1918 in forum 1999 - 2006 (E46)
    Last Post: 09-27-2010, 11:57 PM
  4. High G high speed corner engine bogg...
    By MIMI1 in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 05-13-2009, 11:09 PM
  5. FS: 2003 Z4 2.5i Black Sapphire 5 speed
    By Z4Ciao in forum 3 series & Z Series
    Last Post: 04-29-2008, 09:48 PM
