Results 1 to 4 of 4
Thread: Another Eurosport Twinscrew revival
    Oct 2007
    VA
    00 Mshoe
    If you've seen the ESTS parts/discussion thread it was apparent I found one of the unobtanium kits mostly complete.
    I will be installing it into my 1 of 1 Mcoupe and while I had always planned to turbo the car, plans change as does life, so here we are. I'm not really sure how to document in the F/I section as I don't feel it good to double post everything and I'm at post 409 of my build thread in the Z3 subforum as this car has "been in process" for a while for boost.
    Initially plan to install on the "stock" ESTS pulley and tune.
    I had already started to collect parts for a dedicated boost motor build, and will be lowering the pulley and uping the injectors when the S52 comes out and the Franken motor goes in.
    The ESTS install starts at post 409 as stated in my build thread https://www.bimmerforums.com/forum/s...5#post30861735
    I'd love some input hopefully from some of the ESTS guys on "golden" compression ratio for these as I plan to do custom pistons and rods to target the ESTS power delievery system. I saw jmc put in a specific 0.094 HG that made better power than his 0.140, but I'm not savvy enough yet to say what the differences are there.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    How much boost do you want to run? Will you ever want to run more? What octane fuel will you be using? Is the ECU stock with a tune or standalone?
    Oct 2007
    VA
    00 Mshoe
    As-built is 6-7lbs iirc
    I'll eventually go to a smaller pulley to maybe 11-12
    93 Octane is readily available, I do not plan to run an E-85 (et all) due to not readily available around me
    Stock ECU with tune from ESTS originally, I have all the ROMraider and cables to "self tune" later but may just go straight to TRM as they were the "people" when these kits were new.
    Replies in red
    Jun 2005
    New England
    A twin screw makes full boost at low rpm, in the knock window, 11-12 psi is a fair amount for 93 pump, and a tuned stock ECU has no safeguard beyond the knock sensors. I’d err on the less risky side for compression. I don’t think I would use a 0.098 MLS. That probably gives 9.5 to 10.0:1 compression.
  1. Eurosport Twinscrew S/C
    By eurotekm3 in forum Forced Induction
    Last Post: 03-21-2005, 11:38 PM
  2. Eurosport Twinscrew S/C
    Last Post: 02-14-2005, 10:51 PM
  3. 96m3 EuroSport TwinScrew fs
    By daniel rai in forum BMW Cars For Sale / Wanted
    Last Post: 12-27-2004, 04:13 PM
  4. 96m3 EUROSPORT TWINSCREW fs
    By danrai in forum BMW Cars For Sale / Wanted
    Last Post: 09-14-2004, 08:33 PM
  5. oooohh man EUROSPORT TWINSCREW 4sale
    By ///Molloy in forum Southwestern - US
    Last Post: 09-14-2004, 03:21 PM
