RM European Auto Parts
Results 1 to 5 of 5
Thread: M54b22 running rich
    Jan 2023
    Latvia
    Bmw e46 m54b22
    M54b22 running rich
    Hello guys, so I'm new here.
    I have e46 m54b22 and I didn't get car on road by inspection because it's running to rich.
    Car drives normally but sometimes I can feel gasoline smell in interior. No foulty codes and anything. In inspection I get 3 reading --
    CO(%) on idle 0,130
    CO(%) on trottle 0.030
    And CH(ppm) 122 which shoud be under 100
    So my question is!
    What could couse this to happen. Maybe some of you had the same problem?
    Jul 2004
    Houston, TX
    36 Cylinders
    Does the engine reach operating temperature fully? A thermostat stuck open will make it very hard for the engine to reach warm levels.
    Also your inspection should be with a very hot exhaust system. If the car waited in the parking lot for a while and cooled down, then it will have problems on emissions if tested cold.
    Gasoline smell in the interior is concerning.
    I would read live data and especially what the adaptations are like.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jan 2023
    Latvia
    Bmw e46 m54b22
    Car was siting outside in cold winter for abouth 3 months before I went to inspection. Inspection centre was like 15km away. Engine did get to proper operating temperature fully. And yes I did wait outside for like 20 minutes but engine was in idle and outside was -5 Celsius that day. Maybe exhaust wasn't warm enough.
    Okei, I will test live data. Tnx
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    I agree with everything Abel has told you; but I would like to add:
    90% of the time customers tell me they smell gas, they're actually smelling the oil burning off the exhaust, from a valve cover leak.
    A very dirty air filter can cause a rich mixture.
    Absolutely, if you wait in line for 20 minutes at below-freezing temperatures, you need to start revving the engine when you're next in line. Just keep it at about 2000 or 2500 rpm for the last few minutes before your turn.
    Chris Powell
    BMWCCA 274412
    Jul 2004
    Houston, TX
    36 Cylinders
    I experienced this bit because I failed a European emissions test in the same way, on a very cold day, a few years ago.
    -Abel
  1. Does running rich all the time harm the engine?
    By dqm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-19-2008, 11:01 PM
  2. Replies: 25
    Last Post: 03-10-2003, 03:06 PM
  3. Running rich, I need a good brain here =)
    By Brett in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-19-2002, 03:27 PM
  4. run rich kill o2 sensor.....
    By gsxy in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-29-2002, 12:12 PM
  5. Car is running rich, what should I do???
    By Spencer in forum 1992 - 1999 M3 (E36)
    Last Post: 07-27-2001, 04:29 PM
