Results 1 to 11 of 11
Thread: Remove Body Harness?
    Apr 2003
    Middleton WI
    97 Turbo DCT M3
    I am debating removing the body harness as the car is hardly ever driven on the street and I am mainly keeping it for lights, wipers and power windows but I am thinking about removing all of it since I plan on going with a digital dash and MK60 ABS. Engine and trans are standalone management also. Does anybody that has removed their body harness regret the decision?
    -Mike
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    I don't drive at night, use poly window inserts, and don't drive in the rain so had zero need for a body harness.
    I would remove and wire in whatever switches you need into your switch panel. Get light.
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by olemiss540 View Post
    ^Ditto.
    I have wondered what would happen when someone runs off track in front of me and plasters my windshield with mud.
    louisville ky
    Just thin it out if it’s a track / Racecar.
    Aug 2012
    Central, MD
    1995 M3
    The instrument cluster wiring is probably the main reason to keep some part of the OEM harness.
    I have no "xxxx modules" left in my car, and recently deleted the cluster, so very few OEM wires in the cabin.
    Apr 2003
    Middleton WI
    97 Turbo DCT M3
    I am pretty much at the point where it is a race car only. I sometimes will drive it on the street to do some tuning or car shows. I am ordering a Link dash which is a rebranded aim dash. What solutions have all of you done for the fuel level?
    -Mike
    Aug 2012
    Central, MD
    1995 M3
    I've read that because of the resistance range, the OEM fuel level sensor output side reads 0 to less than 5v, so that should work fine. Would just need to measure it to calibrate and confirm.
    I use one of these, but I'm not sure it's really needed, see above.
    And it doesn't buffer the reading level all that well.
    https://www.bimmerworld.com/Fuel-Lev...r-Adaptor.html
    I have a resistance v gallons table somewhere, if you want.
    The autosports lab wiki on the E36 has some useful info.
    https://wiki.autosportlabs.com/BMW_E36_Guide
    Apr 2003
    Middleton WI
    97 Turbo DCT M3
    Quote Originally Posted by aeronaut View Post
    I like the bimmerworld option, Thanks for the info
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    I've slowly been thinning my cars body harness as I remove parts that aren't needed for track driving.
    I say do it if you can! You'll be surprised how much weight that actually adds to the car.
    Nov 2012
    West Point, Virginia
    2002, 320is, 328is, M3
    I started at the rear of the car and worked towards the fuse box. Removed about a fifty gallon trash can full of wire. Removed wipers, removed window motors and used the slide rails to fabricate a hanger that allows me to put the windows in and lock the car. Only thing I kept was the heater and defroster for cold mornings. Rainy works great. Just put in a new windshield and found some 3m tear offs used in dirt tracking that are going on the new glass
    Bergenfield, NJ
    '99 M3 '10 X5 35d '02 M3
    The only thing I regret is not starting from scratch. Thinning the main harness sucks and I think it would have been much easier to build a new one from scratch had I been able to source all the connectors.
    Otherwise, my advice would be to remove the harness from the car entirely and then start thinning.
  1. Need help with removing body wire harness
    By driftin07 in forum Carolinas
    Last Post: 11-18-2011, 09:50 PM
  2. WTB: E36 Body Harness w/o traction control
    By Carrerax in forum BMW Parts Wanted
    Last Post: 02-17-2004, 04:01 PM
  3. How to remove body moldings?
    By fpgm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-10-2004, 01:09 PM
  4. WTB!! 92-93 E36 Body harness NON-ASC
    By SPAPEXN in forum BMW Parts Wanted
    Last Post: 01-30-2004, 09:50 PM
  5. how to remove body kit on e36
    By ACS320i in forum 1991 - 1999 (E36)
    Last Post: 10-04-2003, 04:41 AM
