So i probably shorted the lights for the climate controls and dashboard gauges, because they are not working and when i replaced the burnt fuse it burned again immediately. Does anyone know where the wires are located so i can fix the short, or is that maybe not the issue here?
(its a 1993 316i sedan)
first of all check which fuse was burnt and you replaced + ir burnt again and then check here in the ETM fuse list details for what this fuse is and then check those items/wires http://wedophones.com/BMWManualsLead.htm
