Results 1 to 13 of 13
Thread: 2002 BMW 325ci convertible transmission issues
    Jan 2023
    USA
    2002 BMW 325i Cabrio
    Transmission warning symbol recently came up and my car went into limp mode (car would also struggle to shift into reverse). A friend of mine cleared the codes and it went back to normal but I got it checked out anyway just to be safe. The mechanic is convinced the transmission (ZF automatic) has to be fully replaced as the transmission fluid is completely black and has metal particles in it, and he says he feels the gears slipping during turns (which I don't really notice myself). I'm wondering if there's any way to be completely sure a full replacement is necessary or if replacing the fluid would be enough. The error codes were gear monitoring 3/4 and a turbine speed fault, which is the exact same as this article in which the issue was the TCM module. As a side note the issues started a couple of days after driving in heavy rain, so hopefully the problem is due to a sensor issue. Any advice would be appreciated!
    Mar 2016
    Portland, OR
    2002 325Ci Cabriolet
    If there are metal particles in the transmission fluid, that means there is now less metal in the transmission. A fluid change is never going to fix that.
    Jan 2023
    USA
    I haven't seen it myself but as far as I understand it's not unusual for some fine particles to be in the fluid due to wear. The transmission also feels fine while I'm driving, it was only when in limp mode that I had issues shifting into reverse. It is very possible that I'll need an entire rebuild but I'm just trying to eliminate all possibilities before making that decision.
    Nov 2018
    La Habra, CA
    2002 525i
    Quote Originally Posted by simoo View Post
    The trans is on the way out. Be thankful it gave you some warning. Mine went south on a drive to San Diego, no warning. Luckily I got it into limp mode and was able to drive in 3rd gear all the way back to LA.
    Oddly, reverse is often the first gear to go in these. The DIY isn't that difficult. But if you can't, look for a low mileage trans and just swap it.
    Current stable:
    2002 525i (Daily Driver)
    1994 SN95 Mustang 'Vert (The Bumblebee)
    2001 325i Convertible (Beach cruiser project)
    Jan 2023
    USA
    I'm still not sure the error was due to a mechanical problem with the transmission. Got the fluid changed today (and filter/ gasket replaced), this is what the magnets and old filter looked like:
    https://ibb.co/JFMswP6
    https://ibb.co/G0TY8dk
    Mar 2016
    leeds, england
    87 Baur, 2004 325 cab se
    How doe`s it drive now ?
    Mart.
    Nov 2018
    La Habra, CA
    2002 525i
    Those are pretty furry, and indicate a very long time between fluid changes. I don't think you ever said how many miles on the trans. How many, and was this its first fluid/filter change?
    Current stable:
    Oldham UK
    '00 330i Sprt '92 525i
    If the ATF level were low, that may account for the lack of drive when cornering as reported by your mechanic. The TCM could also throw a speed sensor fault because what the input sensor is reading is not reflected by what the output speed sensor is reading. The same applies to the gear monitoring fault. The magnets don't look too bad. If the trans has been filled following the procedure closely, you are going to know in a day or too if the fault codes return or the trans goes into limp mode again.
    Jan 2023
    USA
    Car is holding up so far and the transmission still feels fine, we’ll see what happens. Car has 120k miles and as far as I know the tranny fluid had never been changed before (gasket and filter were factory originals). Any idea as to when it’d be good to change the fluid again to eliminate more of the old stuff?
    Jan 2023
    USA
    Sidenote: I got the fluid changed at another mechanic because I wanted to get a second opinion. I went for a drive with him and he said the transmission felt completely fine, so I'm not sure if the first guy noticed something or was just pushing for a transmission change..
    Mar 2016
    leeds, england
    How is it driving now ?
    Mart.
    Jan 2023
    USA
    So far no issues, not sure how to determine what the problem really is/ was...
    Apr 2013
    Mill Valley, CA
    2003 330cic
    You probably had slippage of the friction discs, potentially because of low pressure to one of the cylinders. That oil was really black.
  1. Replies: 0
    Last Post: 10-24-2022, 04:13 PM
  2. 2002 BMW M3 Convertible with SMG Transmission
    By HuntingRidge in forum 3 series & Z Series
    Last Post: 09-30-2015, 02:38 PM
  3. 2002 BMW 325CI Blue on black Convertible COMPLETE part out
    By NexGen7 in forum Whole Parts Cars
    Last Post: 01-05-2014, 03:59 PM
  4. 2001 bmw 325ci convertible top issue
    By speedybimmer12 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-20-2012, 07:37 PM
  5. Replies: 7
    Last Post: 09-10-2006, 07:01 PM
