Results 1 to 20 of 20
Thread: 325e 45 degree coolant temp idle sensor INFO NEEDED
    Mar 2022
    Pennsylvania
    1985 BMW 325e
    Hey everyone, I am looking for some info about a particular sensor on the 325e thermostat housing. This sensor/switch is a 45 degree C (113 F) coolant temp sensor/switch and apparently plays a part in idle control on early model E30 engine management systems. This sensor was also apparently unobtainable until recently, you would have had to make your own sensor or just forget it. The questions I have are, how does this sensor play a part in idle control and what would the absence of this sensor (broken/faulty) cause your cars idle to do. What would the missing information from this sensor cause your car to do when closed at 113 degrees F?
    Jul 2020
    USA
    1986 BMW E30 325
    Here's a very good resource that I believe will answer any questions you may have with the specific functions of the coolant temp switch https://www.e30zone.net/e30wiki/inde...to%20the%20ECU.
    Mar 2022
    Pennsylvania
    1985 BMW 325e
    Hey thanks for the reply, that is not the sensor I am referring to. Here is an image of it https://imgur.com/a/Pq3hFpv
    Aug 2011
    Wake Forest
    2004 525i, 1985 325E
    The only thing I can find on that sensor is "Coolant Temperature switch Closed above 113F for idle speed control". The wiring diagrams show the sensor feeding the ECU and Idle Control Module.
    2004 525i Sport, Manual - 1985 325E Coupe Manual
    Mar 2022
    Pennsylvania
    1985 BMW 325e
    Got it, I'll have to do some testing
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    PN 12631279722
    2 pole switch with yellow insulator found on the thermostat housing. This switch provides input to the idle controller for warm engine operation. Switch is closed above 113° F (45° C). This is an input only for the idle control module (ICM) found in Motronic 1.0 systems. The ICM will raise the idle speed when it thinks the engine is cold (switch open).
    To test measure continuity across the terminals
    Engine cold (< ~113° F (45° C)) - switch open
    Engine warm (> ~113° F (45° C)) - switch closed
    "Howdy, Folks!"
    1998 Avus Blau 328iC - Soon to be sold.
    Mar 2022
    Pennsylvania
    1985 BMW 325e
    So when I start my car, idle will rise with water temp until it temp hits 113 degrees F. At that point, the switch will close, and idle will return/stay at set speed?
    Regina, Sask, Canada
    82 320i 89 325i
    Quote Originally Posted by cole45acp View Post
    it's the opposite. idle comes down as the car warms. at 113f it takes the icm out of the loop and the car runs without. there's no such thing as a set idle speed.
    Mar 2022
    Pennsylvania
    1985 BMW 325e
    Okay understood. Thanks for all the info guys, really appreciate it
    82 320i 89 325i
    you're doing good. you'll figure it out no problem. e's get no love but they are real solid little engines.
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Also it's not a sensor. It's a switch; on or off.
    So cold (switch open) is high idle.
    Warm (switch closed) is normal idle.
    "Howdy, Folks!"
    82 320i 89 325i
    Quote Originally Posted by richardodn View Post
    excellent point.
    Mar 2022
    Pennsylvania
    1985 BMW 325e
    Yep, thanks again guys. I found a company that makes these 45 degree switches and purchased one a month or so ago. It came from Poland so it took awhile to get here. Tonight I measured the new switch for continuity across both terminals and I had no circuit. Put some hot water in a bowl then held the switch in and measured continuity again and had a circuit. I didn't have any doubts that the new sensor wouldn't work, I just wanted to do a little experiment. Also haven't been able to drive my E30 for a week or so but tomorrow I'll test my switch that's in the car before and after driving to see if that one does the same thing. Also, for anyone looking for a new 45 degree temp switch (THE ONE WITH YELLOW TOP) you can buy them from blackstarmanufacture.
    82 320i 89 325i
    nice.
    Mar 2022
    Pennsylvania
    1985 BMW 325e
    Well update, the new 45 degree switch did not fix my idle issue. I tested the old switch and it was working exactly like the new one. But I threw the new one in and went for a drive anyway. 10 minutes of driving and no issues everything was working as it should, all of a sudden my idle starts to surge again when I pushed my clutch in at a stop light. Darn, really thought I was onto something there lol. Back to the penny!
    82 320i 89 325i
    maybe check for vacuum leaks, and / or clean out the idle air control valve. iacv's are getting to be a problem as the cars age.
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Surging idle is most likely a dirty/sticking idle air control valve (ICV).
    "Howdy, Folks!"
    Mar 2022
    Pennsylvania
    1985 BMW 325e
    Yeah thanks guys but unfortunately I’ve already been down the idle control rabbit hole several times over. I suspect a broken/faulty idle control valve too but don’t have the means to finding a good known working one at the moment. Until then I’ll continue to use the penny lol
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    The other suspect part on the early models (Motronic 1.0) is the idle control module (ICM). Motronic 1.0 had idle and engine control as separate modules and the idle module is known to have internal solder issues. Easiest thing is to swap it with a known good and see what happens. A faulty one can be repaired by reflowing the solder on the main connector.
    "Howdy, Folks!"
    Mar 2022
    Pennsylvania
    1985 BMW 325e
    I have replaced mine with a rebuilt one from ProgRama in Boca Raton, FL. You definitely can't go wrong with the guys over there. I honestly just think my ICV is broken/faulty man, I'll tell you the story. My idle was a little unstable one day, looked it up and everyone said just to clean it with some carb cleaner. I sprayed it out and plugged it back in and boom idle started to surge like hell. I'm talking 700-1500 up and down. Maybe I damaged it while cleaning it? I'm not sure, I don't have the means to find a known good working one to try at the moment. I've purchased 2 "working" ones from eBay and ended up returning them because neither of them worked. The weird thing about the whole deal though is, when I cold start the car, I can drive it for about 5-10 minutes until it starts to surge. If I start the car and let it sit and idle, it will start at 700-800 and then over the course of those 5-10 minutes the idle will continue to rise and rise until it hits about 1500. Upon hitting 1500 it will then start to surge up and down infinitely.
  1. Coolant temp sensor fixes idle but weird observation now
    By cnowak1 in forum 1983 - 1991 (E30)
    Last Post: 05-19-2011, 10:47 AM
  2. E34 FS: OEM Engine Coolant Temp. Fan Sensor
    By E39esp in forum E34 Classifieds (closing soon)
    Last Post: 04-04-2011, 04:17 PM
  3. Info needed on blue top coolant temp sensor
    By DmcL in forum 1983 - 1991 (E30)
    Last Post: 06-01-2010, 08:31 AM
  4. coolant temp gauge sensor location on m50?
    By djborya in forum 1991 - 1999 (E36)
    Last Post: 05-14-2007, 05:03 PM
  5. coolant temp gauge not woorking- need advice
    By worldonastrng in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-06-2004, 12:08 PM
