Results 1 to 10 of 10
Thread: 1989 325is Auto to Manual conversion
    Jan 2023
    National City
    BMW 325is
    Hi everyone, Hoping to get some help from anyone about manual conversion. I got a older model Getrag 260 with a metal shifter plate not the aluminum shifter carrier. Anyone know how to mount rear part of the the metal shifter plate to the tunnel or any bracket that I can mount to the transmission so I can use the newer style aluminum shifter? Any info or comment is really appreciated. Thank You
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    The E30 M3 had a bracket to adapt an early transmission to the late shifter carrier, but it isn't a bolt-on fit. There has to be someone that sells those for the G260 by now.
    Jan 2023
    National City
    BMW 325is
    Quote Originally Posted by hotdish View Post
    Thanks for the reply hotdish. I was hoping someone also fabricated a bracket or an adapter for this also by now. I guess not enough market for it. But if I cant find a solution for it I'll just go with a floor mounted shifter from garagistics. Just trying to convert this on a budget. I got a good deal on the swap thats why i bought this.
    Regina, Sask, Canada
    82 320i 89 325i
    Quote Originally Posted by caviteno View Post
    check your manual trans. if there is the two "bunny ears" at the top it'll convert without the m3 bracket. a lot of them came with both the ears and the older style plate. transition began in the 85 - 86 model years.
    you still need everything else from the later shifter. bitch clip, shifter knuckle, rear mount. the m3 bracket might negate some of that.
    Jan 2023
    National City
    BMW 325is
    Quote Originally Posted by 82eye View Post
    unfortunately the one I got doesn't have the bunny ears
    https://freeimage.host/i/HaeLhWN
    82 320i 89 325i
    m3 bracket is probably the way then
    Jan 2023
    National City
    BMW 325is
    I'll try the m3 bracket before i go for th efloor mounted shifter. Thanks 82eye.
    82 320i 89 325i
    cool. the floor mounts always remind me of the stupid ass drifter dongs
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    https://www.realoem.com/bmw/enUS/sho...diagId=25_0081
    Looks like you'll need parts #2-6 with the bracket being #5. The #3 bolts are probably already part of your transmission. The bracket is PN 25112225369 and depending on where you source it can be had for $15-25.
    "Howdy, Folks!"
    Jan 2023
    National City
    BMW 325is
    Quote Originally Posted by richardodn View Post
    I ordered the bracket lets see how it goes. Thanks richardodn
  1. 325i-auto----m3-manual conversion HELP
    By mattm3 in forum Engine Conversions
    Last Post: 12-27-2008, 03:09 PM
  2. 92 325i auto to manual conversion
    By adrnalinjunkee in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-12-2005, 07:01 AM
  3. Replies: 13
    Last Post: 12-09-2003, 06:56 AM
  4. Auto to Manual Conversion Info
    By CrayzeeM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-24-2003, 07:23 AM
  5. Auto to Manual conversion
    By Lee Sung in forum 1991 - 1999 (E36)
    Last Post: 07-06-2002, 04:34 PM
