Results 1 to 3 of 3
Thread: Multi Faults: P0597, P0430, P15C9, P1505, 128i
    Aug 2009
    Ontario, Canada
    2017 M240iX
    2011 128i auto, M-sport, 194,000km.
    Throwing these codes
    P0597 Thermostat Heater Control Unit
    P0439 Catalyst System Efficiency Below Threshold Bank 2
    P15C9 Rear Wheel Speed Sensor (? I think)
    P1505 Idle-Speed Control Value Closing
    The thermostat heater code has been on for a few months, I ordered a water pump to do while I was in there but didn't get around to it yet as I have moved and not completed my garage setup. But I did verify thermostat/waterpump operation with a real-time temperature monitor during spirited driving. All functions as expected with respect to temperature regulation
    Today it lit ABS and traction control lights (and the (!)) as well as the engine light which was already on. Seems to run fine but the codes above come from ODBII. ABS warning showing on the display.
    Battery was changed not too long ago, I coded the correct (changed) battery size and registered it. Ran fine for a few months after that until now.
    So, my first thought is to go after the wheel sensor, some research indicates a dirty tone ring or faulty sensor could be the issue. But I'm a little suspicious about these seemingly unrelated codes all popping at once, could it be a bad ground or other systemic fault? Or should I just replace the O2 sensor, speed sensor, Thermostat, and ICV?
    BTW anyone know of a good R&R guide for the 128i rear ABS sensor and ring? Having trouble finding anything.
    Anyway advice from the E82 gurus here would certainly be appreciated, thanks in advance.
    F22 '17 M240iX
    E82 '11 128i Msport
    E90 '09 323i
    E46 '99 323i
    E36 '98 328i Msport
    E30 '88 325iX
    also, for her:
    F48 '17 X1 Msport
    E83 '09 X3 3.0i SI
    Jul 2004
    Houston, TX
    36 Cylinders
    I suggest getting an error read with a tool capable of reading BMW manufacturer codes in all the modules. P code read in engine control module is not cutting it. OBD code readers are designed to read codes from engine modules and are often vague. They're meant for OBD emissions items.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Aug 2009
    Ontario, Canada
    2017 M240iX
    I have Carly would that work?
  1. Multi Faults: P0597, P0430, P15C9, P1505
    By iXguy in forum 2011 1 Series M Coupe (E82)
    Last Post: 01-07-2023, 03:29 PM
  2. Multi Fault Codes
    By B3M2W3i in forum 1999 - 2006 (E46)
    Last Post: 01-30-2013, 02:52 PM
  3. P0430 fault code, engine just start running like rough/loss of power
    By OptikalPhiber in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-23-2009, 11:54 AM
  4. P0430 fault code, engine just start running like rough/loss of power
    By OptikalPhiber in forum Engine Conversions
    Last Post: 08-22-2009, 04:30 PM
  5. Check Engine fault P0430
    By rumjoky in forum 1991 - 1999 (E36)
    Last Post: 02-02-2008, 09:45 PM
