i assume the float in the brake/clutch reservoir and the wires coming off the reservoir cap are for a level sensor?
i was bleeding the clutch, and i guess i was a little too vigorous moving the cap around: i pulled the cap electrical plug right off its wires.
no big deal, i know there's fluid in there as i just flushed and bled it, and i can repair the connector tomorrow...
but why am i getting no warning lights in the dash?
is this in fact a level sensor?
[1988 m6]
Yes, the bottom of the cap is a level sensor.
If the wires were pulled off the sensor, the circuit will be interrupted to trigger the brake light on the dash.
See page 6210-2 lower left corner
https://www.millerperformancecars.co...g%20Manual.pdf
or, just connect the two if you want to see the light!
Rob E3
thanks guys!
exactly what i was looking for.
interesting that its a normally open switch rather than normally closed.
and thanks for the manual link. the e24 has been the one car of mine that i havent needed to hunt down manuals for... yet.
