Results 1 to 6 of 6
Thread: Coated brake rotors
    Nov 2017
    calgary, canada
    2014 328i xdrive
    Coated brake rotors
    Just installed new fully coated Zimmerman rotors and Breembo pads. Seem to get alot of chattering when breaking ant the coating looks like it's gumming up. (Sorry can't post a photo).
    Is this normal for the first while?
    2014 X3
    Do a bunch of runs with very hard braking, there should have been a slip of paper in the box describing the exact break in process. If not you can Google it, but the coating will be removed by the process when done correctly
    Also hope you applied the correct stuff to the caliper and backside of braking pads to prevent noise
    Nov 2017
    calgary, canada
    2014 328i xdrive
    'Also hope you applied the correct stuff to the caliper and backside of braking pads to prevent noise'
    Yes, I did do that.
    323i E30's Avatar
    323i E30 is offline ⅂!ʈө !ƨ l!ʞө ɐ ʇөlөbµouө
    Jan 2013
    Europe
    M52 E30 touring & E91
    The coating should wear off quite quickly, and the brakes will start to feel better as it does.
    Chattering sounds would have me take it apart again though.
    ^ true story
    D̶i̶b̶s̶ ̶o̶n̶ ̶t̶h̶e̶ ̶E̶2̶1̶
    Dec 2019
    CA
    Bmw 540i 2002 5HP-24
    It wears off quickly, i got zims too. Much better solution than getting new rotors covered in yuck.
    Jun 2021
    New Orleans
    02 E53 X5 4.6 swap
    Crazy, I just posted on xoutpost about problems with the TRW ceramic pads and Zimmerman rotors I put on my e53 X5 a few weeks ago. I was a fan initially after breaking them in per the instructions, but a few weeks later, not so much. After sitting for several days the steering wheel shuddered badly on braking, like a massively warped rotor when my wife picked me up at the airport.
    I pulled the front wheels and verified all the suspension and brake torques were good but found 1/3 of the right rotor badly rusted. I’m positive that this is what was causing the steering wheel to rhythmically shudder on braking. I took the car out again and hammered the brakes per the Zimmerman brake in procedures, again and sure enough, shudder fixed.
    bottom line is that I don’t feel a huge difference in braking with the ceramic pads and Zimmerman rotors, but they are much more quiet than the OEM version I’ve been running for 20 years. I also still can’t say why the steering wheel shudder happened, or if I caused it somehow
    Current BMW
    2002 E53 X5 4.6i (4.4 to 4.6 swap)
    Former BMWs
    1996 BMW Z3
    1998 BMW E36 M3 Sedan
    2004 BMW E46 M3
  1. Replies: 8
    Last Post: 09-12-2019, 01:31 PM
  2. FS: Zimmermann Coat Z Rear Brake Rotors for e39
    By BimmerDriver02 in forum Brake Kits, Rotors & Pads
    Last Post: 09-09-2013, 09:54 PM
  3. Rusted on brake rotors?? Please help..
    By DBP in forum 1991 - 1999 (E36)
    Last Post: 05-23-2001, 09:33 AM
  4. Brakes: Rotors and Pads
    By perot in forum 1991 - 1999 (E36)
    Last Post: 05-09-2001, 12:44 PM
  5. The never-ending brake, rotors and track pads thread
    By Mike Mount in forum 1992 - 1999 M3 (E36)
    Last Post: 03-21-2001, 05:24 PM
