95M3 S50 Engine with 178K total Miles. The work below was performed at 159K Miles. Engine is still in the car and runs awesome. This is a worry free drop in engine. All sensors replaced. Can provide Dyno chart and Oil analysis reports. Price is $4,500 (Neg) Pending options below. Engine still in car. Looking at March Time Frame. Pick-up Charlotte area only.
Engine:
- Schrick Cams 264/256.
- AFE CAI, 3.5” MAF, 24 LB injectors, BW Silicone elbow.
- Custom TRM Dyno tune DME makes 245HP at the wheels.
- Head Gasket Replaced. The head was resurfaced, the valves were reseated with new valve seals and new spring retainer clips installed.
- Replaced Crank Shaft sensor, Cam shaft sensor, upper chain tensioner, lower chain tensioner, upper timing chain, Thermostat (80C), (2) engine coolant sensors, (2) knock sensors, Vanos oil lines, Air Intake sensor, spark plugs. O2 sensor and Throttle position sensor.
- Beisan Vanos seal replacement.
Lower Engine:
- Achilles oil baffle
- Z3 reinforced oil pick up tube
- Oil pump nut wire tied. Idler pulleys and tensioners replaced. Rear Main Seal replaced.
Exhaust:
- S52 Headers with S52 midpipe for better flow. (Car is still OBD I)
Extra Options
* OEM Injectors, OEM Air Box, OEM MAF, OEM DME Chip. S50 exhaust manifold, S50 midpipe. S50M3 Cams. AC Compressor, Dryer.
Not Included: Cat Back Exhaust, Steering Pump. Engine Harness (optional)
Do you still have the original s50 cams available? And if so would you consider selling separately?
Thanks,
Yes the Cams are available, Not sure about shipping to UK?
$3,500 for the Engine / Schrick Cams / DME
Engine will be pulled soon.
Hey there - I'm new to the forums as I just joined based on my interest in your engine. I was going to DM you, but I haven't met the time and number of posts requirement yet for that to be active. I have a 1987 325e that will include an engine swap and I was hoping to ask some questions about your S50. I reside in the Boston area, but travel to the Charlotte area (Mooresville) to visit my family so we could also discuss some logistics ideas. Let me know if you're interested. You can contact me directly - andy.wizorek@gmail.com. Thanks
Sold!
Did you still have the original S50 cams or did they go with the motor
S50 cams available. $425 plus shipping. PM if interested.
